Automation Notification not Firing as Expected
I have some notifications that aren’t firing and I’m sure it’s because they’re all designed the same and I need some help to do what I need it to do.
Here’s the automation:
alias: Notification - 2nd Floor Filter Reminder
description: ''
  - platform: time
    at: '12:00:00'
condition:
  - condition: time
    after: input_datetime.last_2nd_floor_filter_change
  - service: notify.mobile_app_serge_s_s9
      message: Replace 2nd floor vacuum filter
mode: single
What I want this to do:
at 12:00 each day, evaluate the input date for the next filter change. If today is greater than that date, send me a message. Do that again tomorrow at noon if the input date is still in the past.
Example:
At noon, check the 2nd floor input date, if the input date is in the past, send me a message.
I’m sure it’s the preposterous condition I added in there for the input date but I’m not sure how to set it correctly.
The time condition only looks at the time in your helper. See the puke yellow warning box here: https://www.home-assistant.io/docs/scripts/conditions/#time-condition
You will probably need a template condition.
condition:
  - condition: template
     value_template: "{{ {{ now().timestamp() > state_attr('input_datetime.last_2nd_floor_filter_change', 'timestamp')|float(0) }} }}"
That makes sense and yes that puke yellow warning was right there. Great to know going forward.
I reviewed the solution and it makes sense but It’s throwing an error and I can’t tell why. I reviewed this a dozen times and it looks right to me:
Do you know what’s causing it to throw the template error?
I really appreciate the template help, I still struggle with it a lot.
Ugh. Copy paste error on my part. Sorry. Template should be:
 value_template: "{{ now().timestamp() > state_attr('input_datetime.last_2nd_floor_filter_change', 'timestamp')|float(0) }}"
Too many braces. When I copied the test from my template editor I pasted a template inside a template.
