I have a question for experienced ESPhomers. I have environmental sensor SEN55 (particle measurement, NOx, VOC, temp, humidity). This sensor with ESP32 is measuring air quality in the workshop and if needed, it can turn on and control the speed of connected exhaust FAN.
It is working quite well for a year. But, I have all the automation on the HA side. Issue is, when ESP loose its connection, fan did not turn on when some of the value gets over the limit. So, I decided to make the automation independent and make it directly on ESP.
Question is, how do you recommend to approach this task. I started with simple on_value_range trigger. But crash in to problem with Circular dependency as I have a lot of conditions. Why? Because, if some of the value gets over certain level, it has to get priority over others. I tweak this recipe over HA.
You can see what I mean in yaml:
- platform: sen5x
pm_1_0:
name: " PM <1µm Weight concentration"
accuracy_decimals: 0
pm_2_5:
name: " PM <2.5µm Weight concentration"
pm_4_0:
name: " PM <4µm Weight concentration"
pm_10_0:
name: " PM <10µm Weight concentration"
on_value_range:
- below: 50
then:
- fan.turn_on:
speed: 20
- above: 50
then:
- fan.turn_on:
speed: 30
- above: 60
then:
- fan.turn_on:
speed: 40
- above: 70
then:
- fan.turn_on:
speed: 50
- above: 80
then:
- fan.turn_on:
speed: 60
- above: 100
then:
- fan.turn_on:
speed: 70
- above: 120
then:
- fan.turn_on:
speed: 80
- above: 140
then:
- fan.turn_on:
speed: 90
- above: 160
then:
- fan.turn_on:
speed: 100
- below: 80
then:
- if:
condition:
and:
- sensor.in_range:
above: 20
below: 100
then:
- fan.turn_on:
speed: 50
- if:
condition:
sensor.in_range:
above: 100
then:
- fan.turn_on:
speed: 100
- below: 100
then:
- if:
condition:
and:
- sensor.in_range:
below: 20
- sensor.in_range:
above: 200
below: 300
then:
- fan.turn_on:
speed: 30
- if:
condition:
and:
- sensor.in_range:
below: 20
- sensor.in_range:
above: 300
below: 400
then:
- fan.turn_on:
speed: 40
- if:
condition:
and:
- sensor.in_range:
below: 20
- sensor.in_range:
above: 400
then:
- fan.turn_on:
speed: 60
temperature:
humidity:
voc:
algorithm_tuning:
index_offset: 100
learning_time_offset_hours: 12
learning_time_gain_hours: 12
gating_max_duration_minutes: 180
std_initial: 50
gain_factor: 230
nox:
algorithm_tuning:
index_offset: 100
std_initial: 50
gain_factor: 230
temperature_compensation:
offset: 0
normalized_offset_slope: 0
time_constant: 0
acceleration_mode: low
store_baseline: true
address: 0x69
i2c_id: bus_a
update_interval: 10s
output:
- platform: ledc
pin: GPIO1
fan:
- platform: speed
output: FAN
speed_count: 10
I know that this is not bulletproof and has some flaws. If you know about better way how to approach this better, let me know. This is my approach (with AI) to get over the circular dependencies, where I wrote one big automatiton. But I used to have that “on_value_range” for each different measurements. But, when I call the nox_sensor in condition, the compiler doesn’t like it, with circular dependencies. I get a hint somewhere on internet to translate the measurements on “template” sensors, where it might work.
