Automation of gpio Led when known device home
Hi to all,
i want to switch a led on when a known device is in “home” state.
i tried like this in automation.yaml:
# led automation when home
- alias: 'Home Signal'
    platform: state
    entity_id: known_devices.m_honor_90
    state: home
    - service: switch.turn_on
        entity_id: switch.Led_Red
Change “state: home” to “to: home”. Also you need to track a device_tracker entity_id. So verify that you have one defined for your mobile device. The code should then look like this:
i tried changing that, but i´m only getting this error in protocol:
Logger: homeassistant.components.automation
Source: components/automation/config.py:242
Integration: Automatisierung (documentation, issues)
First occurred: 18:44:25 (1 occurrences)
Last logged: 18:44:25
Automation with ID ‘Led anzeige’ could not be validated and has been disabled: required key not provided @ data[‘action’]. Got None required key not provided @ data[‘trigger’]. Got None
this is the switch in configuration.yaml:
##GPIO
# led Gpio switch
switch:
  - platform: rpi_gpio
    ports:
      18: led_red
by clicking on the switch itself it works but not with the automation
Please post your automation yaml. Is device_tracker.m_honor_90 defined?
thanks for your help i found the error:
  description: ''
  - platform: state
    entity_id:
    - device_tracker.m_honor90lite
    to: home
  condition: []
    data: {}
      entity_id: switch.led_red
  mode: single
