Automation of Light on presence detection - trouble adding second condition
I created an automation using the “Automation editor” in the configure menu.
The automation is to turn on a light when I get home if the sun as set, and then turn off 5 minutes later. The code in the automations.yaml is as follows
- id: '1522375322401'
  alias: front lights
  - entity_id: device_tracker.jasonphone, device_tracker.shannonphone
    platform: state
    to: home
  condition:
  - after: sunset
    condition: sun
  - data:
      payload: 'ON'
      topic: cmnd/sonoff-front-out/POWER
    service: mqtt.publish
  - delay: 00:05:00
  - data:
      payload: 'OFF'
I realized later that if the light was already on and it detected me getting home, it would turn off the light after 5 minutes. (dont want this)
what I want to do is add a condition “if the light is off” so that if the light is already on it wont run the automation.
I tried adding it in the automation editor (the resulting code is below).
once I’ve added the second condition though, the automation never runs at all… been puzzling over this for a number of weeks.
  alias: front lights
    platform: state
    to: home
  condition:
  - after: sunset
    condition: sun
  - condition: state
    entity_id: switch.frontoutlight
    state: 'OFF'
  - data:
      payload: 'ON'
  - delay: 00:05:00
  - data:
      payload: 'OFF'
the switch is configured as the following in the config.yaml
switch:
platform: mqtt
friendly_name: Front Outside Lights
command_topic: “cmnd/sonoff-front-out/power”
state_topic: “stat/sonoff-front-out/POWER”
qos: 1
payload_on: “ON”
payload_off: “OFF”
retain: true
any help would be appreciated.
Can you please update your post using code bocks as stated in the blue box above your post. Otherwise it very difficult to see whats wrong with your code.
As for not triggering I think you should not use capital letters for state so try state: 'off'
thank you. that worked
