Automation on groups
Hi community,
can someone please point me how to do a time based automation within a group?
Background:
I’ve defined a group with a lot of LED chains and bulbs in groups.yaml. Now I want them to switch on at 7:00pm and of at 1:00am with automations. In the UI I can only select a device.
Is it realy needed to add every single device to the automation? So for me it will be 21 devices in the list.
Hey Wolly,
would probably be the easiest to just create a light group and use call service as the automation action. There, choose light.turn_on as the service and set the newly created group as the entity_id.
Thanks, seems my approach was not the best one, will try.
It looks like I can’t get the "light group’ to work. Here is what I inserted into the configuration.yaml:
light:
  - platform: group
    entities:
    - switch.xmas_dach_xmas_dach
    - switch.tasmota_xmas_kueche_unten
    - switch.tasmota_xmas_kueche_unten_2
    - switch.tasmota_xmas_nbuero
    - switch.tasmota_xmas_wohnz_oben
    - a.s.o.
But I can’t see any ‘light.xmas_lights’ with my entity_id list.
You can only use light.xyz entities for the light group. Either check Tasmota so that it introduces itself as a light (some SetOption) or use normal groups: https://www.home-assistant.io/integrations/group/
None of those entities are lights.
Using normal groups brings me back to the topic how to use an automation with groups.
  service: homeassistant.turn_on
  entity_id: group.switches_that_should_be_lights
tnx mf_social - that did the job :grinning:
Just to add a tiny bit of information which might be helpful to others - besides homeassistant.turn_on you can also use homeassistant.toggle if you prefer.
