I’m trying to get an automation to run when HASS starts. It needs to check the current state of occupants in the house (input_boolean) and if no one is home it changes alarm status to armed away. Here’s what it looks like:
- alias: 'HA start set alarm on'
platform: homeassistant
event: start
condition:
platform: state
entity_id: group.someone_home
state: 'off'
- service: alarm_control_panel.alarm_arm_away
entity_id: alarm_control_panel.alarm
- service: notify.pushbullet
title: 'Alarm set to Arm Away (restart)'
target: 'device/GalaxyS4'
message: ' '
Unfortunately I’m getting an error in my log and an ‘Invalid Config’ in the web gui. Here’s the error:
17-05-09 15:19:31 WARNING (MainThread) [homeassistant.components.automation.event] Deprecation: Automations should not listen to event 'homeassistant_start'. Use platform 'homeassistant' instead. Feature will be removed in 0.45
I’m using the example here: https://home-assistant.io/docs/automation/trigger/#home-assistant-trigger
I can’t see that what I’m doing is that far off from the provided example:
automation:
# Event can also be 'shutdown'
event: start
Can someone spot what I’m doing wrong? Running HASS 0.43.2
