been searching but can’t seem to find the answer to my issue ,
sometime in about the last fortnight or so the automation option is missing ,
i have blueprints- scenes - and scripts but no automations
tried using a blueprints but not firing because i think due to this,
finally got the ring alarm intergrated but cant do anything with it !
any help greatly appreciated
You have an error in your logs indicating that automations were not loaded, you should post the error in your logs. Also please don’t use screenshots when posting errors or code. Take time to learn how to format code. See this post point 11 to learn how to do that.
cheers for the reply ,
seems i’ve got a lot to learn,just found the logs and have a few errors
Logger: homeassistant.setup
Source: components/device_automation/__init__.py:84
First occurred: 0:05:16 (1 occurrences)
Last logged: 0:05:16
Error during setup of component automation
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 81, in async_get_device_automation_platform
integration = await async_get_integration_with_requirements(hass, domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 50, in async_get_integration_with_requirements
integration = await async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 567, in async_get_integration
raise IntegrationNotFound(domain)
homeassistant.loader.IntegrationNotFound: Integration '' not found.
File "/usr/src/homeassistant/homeassistant/setup.py", line 213, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 175, in async_setup
if not await _async_process_config(hass, config, component):
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 537, in _async_process_config
await async_validate_config_item(
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 75, in async_validate_config_item
config[CONF_ACTION] = await script.async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 144, in async_validate_actions_config
return await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 188, in async_validate_action_config
choose_conf[CONF_SEQUENCE] = await async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 159, in async_validate_action_config
platform = await device_automation.async_get_device_automation_platform(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 84, in async_get_device_automation_platform
raise InvalidDeviceAutomationConfig(
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Integration '' not found
