OK, here are the gory details then…
My automations are actually a python_script (which I hope to move to app_daemon someday).
There is about ~200 lines of conditional code and I maintain an internal state variable so that multiple end devices work together. The point is that at the end of that 200 lines, for each device I end up with a decision to either
- do nothing
- open / turn on
- close / turn off
And then I execute that decision on each device entity. To implement the override or suspend function i now have an extra conditional wrapping around it. This gives you the idea
if (ControlHouseFan):
if (HouseFan == "on"):
hass.services.call('fan', 'turn_on', service_data={ 'entity_id': 'fan.house_fan' }, blocking=True)
elif (HouseFan == "off"):
hass.services.call('fan', 'turn_off', service_data={ 'entity_id': 'fan.house_fan' }, blocking=True)
except you can do it with lists of entities and actions for those entities in a loop.
ControlHouseFan is the override condition, the automation only controls a particular device when it is allowed to. ControlHouseFan is a variable with the value of input_boolean.ControlHouseFan.
Then comes all this “regular automation” code to implement the input_boolean.ControlHouseFan, and this is what I seek to avoid for each device
This is only one device’s override, but it needs
- an input boolean
- an input select to start the suspend for a specified duration
- a timer
- two automations
Here is the automation code to give you the idea.
Not shown, but we also have definitions for the timer, input_boolean, input_select in other files.
- id: Suspend
alias: suspend
initial_state: true
platform: state
entity_id: input_select.suspend_climate
condition:
condition: or
conditions:
- condition: template
value_template: "{{ not is_state('input_select.suspend_climate', 'Running') }}"
value_template: "{{ is_state('automation.call_manage_climate', 'off') }}"
- service: input_boolean.turn_off
entity_id: input_boolean.ControlHouseFan
- service: timer.start
data_template:
entity_id: timer.SuspendHouseFan
duration: "{% if is_state('input_select.suspend_climate', '10 min') %}\n 600\n\
{% elif is_state('input_select.suspend_climate', '30 min') %}\n 1800\n\
{% elif is_state('input_select.suspend_climate', '1 hour') %}\n 3600\n\
{% elif is_state('input_select.suspend_climate', '2 hour') %}\n 7400\n\
{% elif is_state('input_select.suspend_climate', '4 hour') %}\n 14400\n\
{% elif is_state('input_select.suspend_climate', '8 hour') %}\n 28800\n\
{% elif is_state('input_select.suspend_climate', '24 hour') %}\n 86400\n\
{% elif is_state('input_select.suspend_climate', 'Permanently') %}\n 31536000\n\
{% else %}\n 10\n{% endif %}\n"
- id: Restore
alias: restore
initial_state: true
- platform: event
event_type: timer.finished
event_data:
entity_id: timer.suspend_climate
entity_id: automation.ControlHouseFan
So my request is to be able to set an attribute on fan.house_fan (and other devices), call it “auto_suspend_time”. Then have that timer automatically kick in and prevent the execution of (new) services auto_turn_on / auto_turn_off.
The timer starts any time turn_on / turn off are called. But those regular services are not otherwise effected by the timer - because the regular switch should always work.
But calls to auto_turn_on / auto_turn_off would be ignored if the timer was activated.
