Hi All i am very new here to this, and my coding skills are somewhat limited. so i hope that even though it might seem a bit simple some of my questions please do cut me some slack.
So here is what i want to do. when i leave the house it should turn of the lights when i get near the house it should turn on some lights. this should be fairly easy i hope.
i have Owntracks set up with CloudMQTT. owntracks when it broadcasts is visible in cloud mqtt, all that seems good.
I have my zones.yaml file set up with a specific zone.
i have my configuration.yaml to !include zonez.yaml.
Even when checking my config it says it should work.
I have set up the following in my automations.yaml file:
Thank you for the update, i tried moving some stuff around and it works now, however i also created an automation using the automation tool within home assistant, now my code is all mixed up and i can not figure our what i can delete and still have this thing working and what in the code actually made the the lights in the front yard go off when i came home tonight.
my code looks like this now, i know it is a bit much to ask but i need a little help clearing it up, could you help once more?
- alias: Automation 1
platform: zone
entity_id: device_tracker.nicholas_iphone
zone: zone.home
event: enter
service: light.turn_on
entity_id: light.udenfor_1 light.udenfor_2 light.udenfor_3 light.udenfor_4 light.udenfor_5
- alias: Automation 2
platform: zone
zone: zone.home
event: leave
service: light.turn_off
- id: '1549815358485'
alias: turn on lights when home
- entity_id: device_tracker.nicholas_nicholas
event: enter
platform: zone
zone: zone.home
condition: []
- data: {}
i now get this error message when i check my config:
Invalid config for [automation]: not a valid value for dictionary value @ data[‘action’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 71). Please check the docs at https://home-assistant.io/components/automation/
line 71 is the beging of the !include automations.yaml
This will be the proper formatting to fix the entity_ids for the first two automations but in the third automation you don’t have an entity_id selected for the light.turn_on service so you will still get errors if you try to use these without fixing that first:
thank you very much, the third one was a double one anyway so i do not need it. thanks for your help… i will carry on with my next step which is adding that this should only happen 1 hour before the sun sets on the lights turning on automation.
However this will be my own headache. appreciate the help.
