Is just upgraded to 0.50.1 and now get the following error which didn’t appear in the previous version: ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [state] is an invalid option for [automation]. Check: automation->trigger->0->state. (See /home/homeassistant/.homeassistant/configuration.yaml, line 131). Please check the docs at https://home-assistant.io/components/automation/
Automations: The state trigger keyword state and the time trigger keyword after were deprecated in 0.46. They have now been removed. Use to and at instead. (@amelchio - #8510) (automation.state docs) (automation.time docs) (breaking change)
