I have set up automation to turn my lights on at sunset and and off 3 hours later.
The on works fine but off trigger is not working for some reason
alias: Pergola Lights Off
description: If they are on after sunset then turn them off 3 hours later
- platform: device
type: turned_on
device_id: b693a2083fdad3599bac19658a82d9c1
entity_id: c419333733866ae4df2d3e7c3e511bb6
domain: light
condition:
- condition: sun
after: sunset
after_offset: '03:00:00'
- service: light.turn_off
metadata: {}
data: {}
area_id: garden
entity_id: light.pergola_strip
mode: single
Looking at the trace I am seeing that it confirms that it’s 3 hours after sunset, but nothing happens after that until I manually turn the lights off many hours later.
"When the light is turned on 3 or more hours after sunset, turn it off.
Again, that is not what it says. Conditions are not Waits, they are checked immediately after the trigger event. The condition is testing if it is at least 3 hours after sunset. As the next line states, the condition failed and the script stopped without executing the action.
You should trigger on the Sun instead.
description: 3 hours after sunset turn off the pergola lights
- platform: sun
event: sunset
offset: "03:00:00"
condition: []
metadata: {}
data: {}
mode: single
