I hope someone can point out my mistake here.
I have created an automation that checks every hour if devices have been accidentally left on.
Part of the automation checks the following:
- No movement has been detected in the room for at least three hours
AND - Has the air conditioner been on for at least 3 hours (since there is no ON mode, I set the check to NOT OFF)
If both apply, the air conditioning should be switched off.
In the test, there was no movement for over 3 hours. The air conditioning has not been running for 3 hours. However, it keeps getting turned off.
Here is the code of the relevant part of the automation:
if:
- condition: and
conditions:
- condition: state
entity_id: binary_sensor.workstatt_bewegung
state: 'off'
for:
hours: 2
minutes: 0
seconds: 0
alias: Workstatt keine Bewegung
- condition: not
conditions:
- condition: state
entity_id: climate.daikinap06219
state: 'off'
for:
hours: 3
minutes: 0
seconds: 0
attribute: hvac_action
alias: Prüfe - Klimaanlage ist NICHT aus
alias: Prüfe UND - Workstatt keine Bewegung und Klima nicht aus
then:
- device_id: a2afbdadffc9ab87e3a5ac3a9d0e81c5
domain: climate
type: set_hvac_mode
hvac_mode: 'off'
alias: Klimaanlage ausschalten
alias: Klimaanlage Workstatt aus bei Abwesenheit
enabled: true
The follow up says:
Executed: 19. Januar 2023 um 09:00:00
Result:
choice: then
if
Result:
result: true
if/condition/0
Result:
result: true
if/condition/0/conditions/0
Result:
result: true
if/condition/0/conditions/0/entity_id/0
Result:
result: true
state: 'off'
duration: '2023-01-19T06:00:00.142520+00:00'
if/condition/0/conditions/1
Result:
result: true
if/condition/0/conditions/1/conditions/0
Result:
result: false
if/condition/0/conditions/1/conditions/0/entity_id/0
Result:
result: false
state: heating
wanted_state: 'off'
Here are the air conditioning options:
hvac_modes:
- fan_only
- dry
- cool
- heat
- heat_cool
- 'off'
min_temp: 7
max_temp: 35
target_temp_step: 1
fan_modes:
- Auto
- Silence
- '1'
- '2'
- '3'
- '4'
- '5'
preset_modes:
- none
- away
- eco
- boost
swing_modes:
- 'Off'
- Vertical
- Horizontal
- 3D
current_temperature: 9
temperature: 12
fan_mode: '4'
hvac_action: heating
preset_mode: none
swing_mode: Vertical
friendly_name: Workstatt Klimaanlage
supported_features: 57
Can someone help me where the error is?
Greetings Werner
