Automation: Reading an attribute and publishing it to MQTT
This works to send relay state 0/1 to mqtt
- id: relay1_state_to_mqtt
  alias: Relay1_State_ToMqtt
  initial_state: 'on'
    - platform: state
      entity_id: switch.qubino_zmnhadx_flush_1_relay_switch
    - service: mqtt.publish
        topic: "service/hasszw1/device/relay_1/state"
        payload_template: '{% if is_state("switch.qubino_zmnhadx_flush_1_relay_switch","on") %}1{% else %}0{% endif %}'
        retain: true
but this ALWAYS publishes 1
- id: relay1_failed_to_mqtt
  alias: Relay1_Failed_ToMqtt
  initial_state: 'on'
    platform: state
    entity_id: zwave.qubino_zmnhadx_flush_1_relay
        topic: "service/hasszw1/device/relay_1/failed"
        payload_template: '{% if is_state("zwave.qubino_zmnhadx_flush_1_relay.attributes.is_failed",false) %}0{% else %}1{% endif %}'
        retain: true
If I replace the payload template with
payload_template: "{{states.zwave.qubino_zmnhadx_flush_1_relay.attributes.is_failed}}"
Then I get True and False.
I’ve tried using in the line
multiple values: false, False, “false”, “False”. None of it worked - the result is always 1.
I’m almost pulling my hair…
Thank you for your time!
use is_state_attr
 {% if is_state_attr("zwave.qubino_zmnhadx_flush_1_relay","is_failed",false) %}0{% else %}1{% endif %}
