I am trying to configure a input number (slider) for a home irrigation system using MQTT on a 4 channel Sonoff running Tasmota. An automation was created to forward the value of the slider to tasmota via MQTT.
When using the service mqtt.publish to publish the code below, it work’s!
{ "topic": "cmnd/sonoff/Timer1", "payload_template": {"Time":"{{ states('input_number.slider1') }}"} }
However, when the same service and data is inputed into an automation as an action, the Tasmota console shows “Invalid JSON” when the automation is triggered.
The following message was received while monitoring with an MQTT app on an iPhone.
cmnd/sonoff/Timer1
OrderedDict([(‘{time’, " 4.0}")])
where ‘4’ was the number set on the slider.
Here is my automation from automations.yaml
- id: ‘1537040514181’
alias: slider test
- entity_id: input_number.slider1
platform: state
condition:
action:- data:
payload_template:
Time: ‘{ states(’‘input_number.slider1’‘) }’
topic: cmnd/sonoff/Timer1
service: mqtt.publish
I’m wondering how this can be resolved to broadcast the same message as if it was entered from the service screen in home assistant.
