I have a script that turns my house “on”, and an automation to trigger that at 5:10:00AM. It was working fine, but this week I noticed one of the devices is switched on then off every morning. It wasn’t doing this until about 3 days ago. According the the trace, the automation clearly thinks it is supposed to wait 1 second then turn off the pantry switch.
Here are my scripts and logs, but I don’t see any reason for it to turn off. What else could I check?
script
alias: House - On
sequence:
- type: turn_on
device_id: 7e342ea3774bb2cde470acbb0aa32454
entity_id: switch.pantry_outlet
domain: switch
- type: turn_on
device_id: fe81692f4ac99371f8aab5ad1afd5546
entity_id: switch.family_room_lamp
domain: switch
mode: single
automation
alias: House On
description: ""
- platform: time
at: "05:10:00"
condition: []
- service: script.house_on
data: {}
mode: single
trace from this morning Notice the 1second wait and then pantry outlet is turned off
Go to Developer Tools → States and confirm the state of switch.pantry_outlet is currently off.
Go to Developer Tools → Services and use the switch.turn_on service to turn on switch.pantry_outlet.
Go to Developer Tools → States and check if the state of switch.pantry_outlet is in fact on or if it has reverted to off.
If it’s off then it implies there’s a communication problem with that device. When Home Assistant transmits a ‘turn on’ command to the device it expects it to promptly reply with an acknowledgement confirming it has turned on. If no timely acknowledgment is received from the device, Home Assistant reverts the device’s state to off. This might be what has been happening for the past 3 days.
In that case, what happens when you manually execute script.house_on (i.e. not triggered via the automation but either from Developer Tools → Services or from the Configuration → Automations & Scenes → Scripts view)?
No. I’m going to reboot the host and see if something is just off. Maybe the recent patch update to .5/6 messed something up. I guess I’ll report back tomorrow
