Hello guys.
First, I’m totally new to HA - but read around…. Coming from an OpenHan installation….
I have a KNX outdoor Lux sensor, which sends data every 5 minutes…
When I create an automation to trigger on this one it will always turn on the lights if the lux < set point….
Is there a smart way handling this? I need a “Bit” value I can set to True when the lamp is set to “On” first time on the lux sensor - then the automation shall not run anymore as long as this bit is “True”
