I’ve got a small automation that should only run in december and January (Winter time in Holland) and only in the morning hour.
Because my girlfriend so now and then uses the alarm during the day, I have to conditions in this automation.
- It has to be december or january AND
- it has to be between 05.00 and 08.00
In Siri Shortucts I’ve got a little automation that runs when the alarm is turned of.
The Siri Shortuct automation works and fires the automation in Home Assistant, but then the problem is that it runs, also if the conditions are not met. When it’s 08.40 (screenshot) the automation also runs.
What is going wrong here?
