Hello, it would be useful IMHO to insert the drag and drop functionality also in the actions of the automations and scripts as well or instead of the up - down arrows.
Thank you!
Alternatively it would be useful for example: “insert action above”, “insert action below” perhaps using the three dots of the existing actions of the automation (where at the moment there is “Run action”, “Edit in yaml” etc).
Could it be a good solution?
This!
Also, maybe make it easyer to build automations.
I’m having trouble for example, adding a choose function at the beginning of an automation.
Then i need to re-enter the whole flow, instead it would be nice to link the existing flow to the choose function. And selected command blocks to the other choice.
