Hello everybody,
is there any way to edit a yaml file like configuration.yaml via an automation or a script? i want to implement an easy way to add something automaticaly to the configuration of home assistant.
Thanks in advance.
Hello everybody,
Thanks in advance.
Perhaps with sed?
You would create a shell-script, that accepts variables and employs sed, and call it from Home Assistant via the Shell Command integration.
Thank you. I managed to add something to a yaml, but i don’t know how i can add variables to the script.
