Hey everybody,
How may I fade-in my sonos speaker slowly to a specified volume_level in an automation or script?
Thanks!
mny
Hey everybody,
Thanks!
mny
Usually I have to adjust the volume like this:
- service: media_player.volume_set
entity_id: media_player.wohnzimmer
volume_level: 0.15
Is it possible to use a for … endfor loop for it?
Also looking to do something like this with scripts. I quite like how setting alarms on sonos fade in and how timers fade out. Perfect for an alarm automation.
Unless I’m wrong, I’m not sure this is possible with scripts unless you manually set it to run with delays, but I think that might be a bit too convoluted for something as simple as fading up or down. If someone knows a way to do this, I’d love to actually try it!
Another way I can think of doing this is with a function node with Node Red. I’ve yet to test it, but you could try this and see if it works;
let vol = 0.00; // Volume Level
let maxVol = 0.3; //Maximum Volume Level
let interval = 300; //miliseconds
fade()
var timer = setInterval(fade, interval); //Set Timer
function fade() {
//If Volume is greater or equal to Max Volume
if(vol >= maxVol){
clearInterval(timer); // Stop Timer
else{
node.send({payload:parseFloat(vol.toFixed(2))}); //send payload asynchronously
vol=vol + 0.01; //add by 0.01
