matteos1
(Matteo)
June 21, 2019, 1:04pm
1
Hi.I’m new to scripts.
could I ask what’s wrong with this automation and this script?
@ pnbruckner
automation:
- id: 'Co2 Cucina light'
alias: Co2 Cucina light
platform: numeric_state
entity_id: sensor.netatmo_cucina_co2
above: 1500
condition:
condition: time
after: '08:00'
before: '21:00'
- service: script.turn_on
entity_id: script.flash_room
variables:
entity_id: 'light.gateway_light_f0b4299a4613'
brightness: '255'
rgb_color: '[255, 0, 0]'
- delay: 0:03
- service: script.turn_off
entity_id: script.flash_cancel
script
flash_room:
alias: Flash Room
sequence:
- alias: Gateway flash on
service: light.turn_on
data_template:
entity_id: "{{ entity_id }}"
brightness: "{{ brightness }}"
rgb_color: "{{ rgb_color }}"
- delay:
# time for flash light on
seconds: 1
- alias: Gateway flash Off
service: light.turn_off
data_template:
- alias: loop room
entity_id: script.flash_loop
# LOOP BACK TO START FLASH AGAIN
flash_loop:
alias: Flash loop
sequence:
- delay:
# time for flash light off
seconds: 1
- alias: loop_room
# CANCEL FLASHING
flash_cancel:
alias: Cancel Light Flash
sequence:
- service: light.turn_off
data_template:
123
(Taras)
June 21, 2019, 6:23pm
2
At what point does it fail?
123
(Taras)
June 21, 2019, 8:24pm
4
Are there any error messages in the system log?
Possibly an error message reporting the inability to run a script that’s already running?
matteos1
(Matteo)
June 21, 2019, 8:35pm
5
There are no message of error the configuration is ok. But don’t flash
123
(Taras)
June 21, 2019, 10:15pm
6
I’m not looking for configuration errors, I’m looking for errors reported to the system log when you run the automation and scripts.
I tested your automation and scripts and they produced errors in the system log.
The errors indicate a problem with the way you call script.flash_room
. This script uses variables. Whenever you call the script without supplying variables, it fails (and reports an error in the system log).
In the automation, you call the script with variables:
variables:
brightness: '255'
However, at the end of the automation you call it without supplying variables.
The same thing is done in script.flash_loop
. It calls script.flash_room
without supplying variables:
- alias: loop_room
matteos1
(Matteo)
June 21, 2019, 10:27pm
7
here I can easily put the variables
but here I don’t know how to do this because this script must be valid for more automations. if I insert the variables inside the script, the script can be valid only for an authorization.
with this script I should check three automations and then three gateways
- alias: loop_room
# sensor da cambiare
above: 500 #1500
condition:
condition: time
after: '08:00'
before: '21:00'
- service: script.flash_room
data_template:
# id gateway da cambiare
- delay: 0:03
data_template:
flash_room:
alias: Flash Room
sequence:
data_template:
brightness: 255
rgb_color: [255, 0, 0]
- delay:
seconds: 1
data_template:
- alias: loop room
flash_loop:
alias: Flash loop
sequence:
- delay:
seconds: 1
- alias: loop_room
# CANCEL FLASHING
flash_cancel:
sequence:
data_template:
123
(Taras)
June 21, 2019, 10:55pm
8
I modified your code to work in my environment and succeeded in making it flash a light.
Try this:
Automation
- alias: 'Co2 Cucina light'
above: 1500
condition:
condition: time
after: '08:00'
before: '21:00'
- delay: '00:00:15'
- service: script.flash_cancel
Scripts
flash_room:
alias: Flash Room
sequence:
- service: light.turn_on
data_template:
- delay:
seconds: 2
data_template:
- service: script.flash_loop
data_template:
flash_loop:
alias: Flash loop
sequence:
- delay:
seconds: 2
data_template:
flash_cancel:
sequence:
data_template:
If that works then you can adjust the delay
time and put back brightness
and rgb_color
(I removed them for testing purposes).
matteos1
(Matteo)
June 22, 2019, 10:29am
9
@123
script
flash_room:
alias: Flash Room
sequence:
data_template:
rgb_color: ["{{ rgb_color }}"]
- delay:
seconds: 2
data_template:
data_template:
flash_loop:
alias: Flash loop
sequence:
- delay:
seconds: 2
data_template:
flash_cancel:
sequence:
data_template:
automation
above: 1500
condition:
condition: time
after: '08:00'
before: '21:00'
brightness: '255'
rgb_color: '255, 108, 145'
- delay: '00:01:00'
error
Error executing script script.flash_room. Invalid data for call_service at pos 1: None for dictionary value @ data[‘rgb_color’]
Error while executing automation automation.co2_cucina_light. Invalid data for call_service at pos 1: None for dictionary value @ data[‘rgb_color’]
it appears that it does not pass the RGB value and creates error in the script.
I made several attempts but my own RGB which is wrong
tom_l
June 22, 2019, 10:47am
10
RGB colour has to be supplied as a list, like this:
brightness: 255
rgb_color: [255,108,145] ### <-------format it like this.
Also your brightness should be a number not a string (so no quotes), though I think it will still work.
matteos1
(Matteo)
June 22, 2019, 10:50am
11
tom_l:
yes I know but I can’t pass the value to the script. I have already tried to pass the value with the syntax
rgb_color: ‘[255,108,145]’
but the script returns that type of error
matteos1
(Matteo)
June 22, 2019, 10:52am
12
I also tried to put this kind of syntax believing that the script formatted the value as an array but it doesn’t work
tom_l
June 22, 2019, 10:56am
13
I seem to remember having a similar problem. My solution was to use color_name:
instead. List of names: https://www.w3.org/TR/css-color-3/#svg-color
123
(Taras)
June 22, 2019, 11:13am
14
Correct because values are passed as strings . The rgb_color
value you want to pass is a list but it will get converted into a string when passed to the script. The easiest workaround is the one tom_I offered: use color_name
matteos1
(Matteo)
June 22, 2019, 11:16am
15
123:
color_name
I think the gateway doesn’t take color_name but now I try.
matteos1
(Matteo)
June 22, 2019, 12:15pm
16
now it work
thank you
automation
above: 1500
condition:
condition: time
after: '08:00'
before: '21:00'
brightness: '255'
color_name: 'red'
- delay: '00:01:00'
script:
flash_room:
alias: Flash Room
sequence:
data_template:
color_name: "{{ color_name }}"
- delay:
seconds: 1
data_template:
data_template:
flash_loop:
alias: Flash loop
sequence:
- delay:
seconds: 1
data_template:
flash_cancel:
sequence:
data_template:
123
(Taras)
June 22, 2019, 12:47pm
17
Do you know if light.gateway_light_f0b4299a4613
supports the light component’s flash
option?
You can test it using the Services page.
For ‘Service’, select light.turn_on
For ‘Entity’ enter light.gateway_light_f0b4299a4613
For ‘Service Data’ use {"entity_id": "light.gateway_light_f0b4299a4613", "brightness": "255", "color_name": "red", "flash": "short"}
Click the CALL SERVICE button
matteos1
(Matteo)
June 22, 2019, 12:52pm
18
light.gateway_light_xxxxxx not support the light component’s flash
option.
123
(Taras)
June 22, 2019, 2:28pm
19
Oh well, it was worth trying.
Glad to hear the revised scripts are now working properly.
