Issue in 2023.7.1
When I search for a device (Search for ‘friendly name’) to use it as a trigger for an automation I didn’t find it even though it is in the Picklist of all devices.
This happens with some devices (no matter what type of integration), but not with all
Works fine with 2023.6
Steps to reproduce the issue
Start to create a new automation
Select devices as a trigger
search for device by entering the name (friendly name)
If you use the device trigger, it is only the first step to find the right entity state (its a second input box)
Finaly its more or less the same and works as well.
May be, becaus a very popular youtub channel (Simon42) explainend how to setup an automation in HA. In this video he used device/entity-state as a trigger.
Looks there are 2 different options with the same result.
As long as there are both options available, the search funktion should work…
I can confirm I have the same issue. In my installation, all of the missing devices are z-wave (JS) devices like scene controllers and motion sensors. My existing automations still exist and work, I can edit them, but I cannot find the same device in the dropdown list anymore if I re-enter the same name in the device field. This worked fine in 2023.6 and earlier.
Using the Status>Entity as a trigger also doesn’t work for me, since devices like these don’t (always) have entities for the buttons you press or the motion triggers. The only way these work as a trigger for an automation is by using the device type trigger.
