I was playing around with automations and tried switching off of the hot water storage charging + sending a notification based on the condition power consumption on the P1 smart meter above x.
The condition triggered ok because I received the notification but the command to the ebusd device did not seem to change the state of the device. So I initially disabled the automation. After some hours I noticed that another ebus device was switched off every 15 minutes, and switched back on after 4 minutes.
So I tought I made some mistake and removed the automation, restarted the ebus deamon, even restarted the Raspbery Pi multiple times, but the strange thing is that the symptoms are reappearing when the deamon is started/running.
Looks like the ghost automation that is still running, I searched thru logs and states but I have no clue what/where to look for.
