I have an issue with my automation. I want HA to set the volume of my Sonos based on the source. I have as source, TV, TTS (empty source) or the name of a radio, media, etc. I can set the volume by TV and any other source. However, when I send a TTS command to my Sonos, the source is temporary empty or not existing. How can I check if the source is existing or not?
I have the following automation right now:
alias: living_room_media_speaker_set_volume_by_source
- platform: state
entity_id: media_player.living_room_media_speaker
attribute: source
condition: []
- service: script.living_room_media_speaker_set_volume
volume_level: >-
{% if state_attr(trigger.entity_id, 'source') == 'TV' %}
0.16
{% elif state_attr(trigger.entity_id, 'source') == '' %}
0.20
{% else %}
0.12
{% endif %}
mode: single
The == ‘’ does not work. I tried | length == 0, but that doesn’t work also as it can not find the source as an entity during tts output.
Edit: found the solution:
{% elif state_attr(trigger.entity_id, 'source') is none %}
