Automation - setting variable based on date time in a blueprint
Hi all, I’m looking for a way to set a variable for my air conditioner fan_mode, based on what time it runs.
What I would like to achieve in my blueprint is that (metalanguage below):
- choose:
  - conditions:
    - condition:
      if time in range(09:00:00AM ~ 21:00:00PM): then
        set fan_mode: low
      elif time in range(21:00:00PM ~ 09:00:00AM): then
        set fan_mode: auto
Here below the full current blueprint snippet:
blueprint:
  name: Automatic A/C Control based on Temperature
  description: "## Fan ON/OFF Automation based on temperature, outside temperature.\n\nFan
    turns on if the following conditions are met:\n  temperature inside greater than
    your set threshold value\n  temperature outside is lower than your set maximum
    value (to prevent turning the fan on in winter)\n\nFan turns off if the following
    conditions are met:\n  temperature inside is lower than your threshold value minus
    the hystersis value\n  What the automation **NOT** observes:\n  manual fan control.
    Adapt the given values too your needs.\n  If you manually turn the fan on and
    the inside temperature is below the threshold your fan will turn off soon.\n\nWhat
    you need:\n  a fan entity. if you control your fan via a switch entity (via smart
    plug for example) you can create a template fan entity.\n  sensor entities for
    inside and outside temperature. (if you want to use the weather domain than create
    a template sensor from the temp attribute)\n  Inspired by Sam04"
  domain: automation
  input:
    air_conditioner:
      name: Air Conditioner
      description: Air Conditioner to control
      selector:
        entity:
          domain: climate
    presence_sensor:
      description: Only turn on air conditioner if someone is home
      selector:
        entity:
          domain: person
    windows_sensor:
      description: Only turn on air conditioner if windows are closed
      selector:
        entity:
          domain: binary_sensor
          device_class: window
          multiple: false
    temp_inside:
      description: Temperature to track inside your house
      selector:
        entity:
          domain: sensor
          device_class: temperature
          multiple: false
    temp_outside:
      description: Temperature outside to prevent to turn on the fan in winter for
        example. Set to same Temperature Inside entity if you don't want to use it
      selector:
        entity:
          domain: sensor
          multiple: false
    temp_outside_min:
      name: Outside temperature
      description: outside temperature that must be reached to turn on the fan (to
        prevent the fan to be turned on in winter). Set to 0 to disable
      selector:
        number:
          min: 0.0
          max: 300.0
          step: 0.5
          unit_of_measurement: °C | °F
          mode: slider
    temp_threshold_inside:
      name: Inside temperature threshold
      description: inside threshold temperature that must be reached to turn on the
        fan
      selector:
        number:
          min: 0.0
          max: 300.0
          step: 0.5
          mode: slider
    hysteresis:
      description: The difference the observed value must be lower than the threshold
        value before the fan is turned off
      selector:
        number:
          min: 0.5
          max: 100.0
          step: 0.5
          mode: slider
  source_url: https://community.home-assistant.io/t/automatic-temperature-fan-control/350172
variables:
  air_conditioner: !input 'air_conditioner'
  presence_sensor: !input 'presence_sensor'
  windows_sensor: !input 'windows_sensor'
  temp_inside_entity: !input 'temp_inside'
  temp_inside: '{{ states[temp_inside_entity].state }}'
  temp_outside_entity: !input 'temp_outside'
  temp_outside: '{{ states[temp_outside_entity].state }}'
  temp_threshold_inside: !input 'temp_threshold_inside'
  temp_outside_min: !input 'temp_outside_min'
  hysteresis: !input 'hysteresis'
max_exceeded: silent
- platform: state
  entity_id: !input 'temp_inside'
- platform: time_pattern
  minutes: /1
condition: []
- choose:
  - conditions:
    - alias: temp inside greater than temp threshold value
      condition: template
      value_template: '{{ temp_inside|float > temp_threshold_inside|float }}'
    - alias: temp outside greater than outside min temp
      condition: template
      value_template: '{{ temp_outside|float > temp_outside_min|float }}'
    - condition: state
      entity_id: !input 'presence_sensor'
      state: 'home'
    - condition: state
      entity_id: !input 'windows_sensor'
      state: 'off'
    - condition: state
      entity_id: !input 'air_conditioner'
      state: 'off'
    sequence:
    - service: climate.turn_on
    - service: climate.set_hvac_mode
        hvac_mode: cool
    - service: climate.set_temperature
        hvac_mode: cool
        temperature: 24
    - service: climate.set_swing_mode
        swing_mode: fixedTop
    - service: climate.set_fan_mode
        fan_mode: low
  - conditions:
    - condition: or
      conditions:
      - condition: state
        state: 'on'
        for:
          hours: 0
          minutes: 2
          seconds: 0
      - condition: state
        state: 'not_home'
      - condition: state
        state: 'on'
      - condition: template
        value_template: '{{ (temp_threshold_inside - hysteresis)|float > temp_inside|float }}'
    sequence:
    - service: climate.turn_off
  default: []
mode: single
Is this somehow achievable? any suggestion?
Thanks in advance,
Antonio
        fan_mode: "{{ 'low' if 9 <= now().hour < 21 else 'auto' }}"
I just tried it but it doesn’t work :frowning:
This works well!
        fan_mode: "{{ 'low' if now().hour >= 21 or now().hour < 9 else 'auto' }}"
Proof that the template works:
It reports low if the current hour is greater or equal to 9 and less than 21 otherwise it reports auto .
That’s what you originally requested:
set fan_mode: low
