Automation shut off all switches , help needed
I am trying to create a simple automation to turn off all the lights when all device trackers are “not_home”, but even if one device tracker is not_home the automation executes.
I would appreciate any help with this:
automation:
  alias: Lights Off
    - platform: state
      entity_id: group.all_devices
      to: 'not_home'
    service: switch.turn_off
    entity_id: group.all_switches
Thanks!
A cleaner way is to use the device_sunlight_trigger…
Putting these four lines in to your configuration.yaml will have the following effects:
  • All lights will switch off when nobody is home.
  • If it is dark and somebody comes home, the light (or group) defined in the light_group line will come on.
  • If somebody is home and it starts to get dark, the light (or group) defined in the light_group line will come on, slowly fading in as the sun goes down
device_sun_light_trigger:
  light_group: [light_or_group_to_switch_on]
  light_profile: relax
  device_group: group.all_devices
No need for an automation unless you want something more complicated, like different lights depending on who comes home etc.
Thanks for the tip!
only just discovered this, im trying to find info on the light_profiles. Are they also built in, and applicable out of the box, or do we have to create these ourselves?
thx,
marius
Howdy @Mariusthvdb, it looks like from the light component page that there are four light profiles built into Home Assistant, but that you can add additional ones to light_profiles.csv . Follow the link mentioned in the light_profile parameter to see what the existing profiles look like (click on the raw version on github).
wonderful, thanks.
if i were to add profiles, where should this light_profiles.csv file reside? In the /config folder?
That’s my guess too.
Was /config in fact the correct location? I’m trying to determine this as well.
