Automation State trigger triggers also by an entity-state "unavailable"
I’ve setup the following automation:
alias: Solar Battery Discharge/Charge Correction
description: Solar Battery Discharge/Charge Correction
  - platform: state
    entity_id: sensor.inverter_efficiency_loss_daily
    not_from:
      - unknown
      - unavailable
condition: []
  - choose:
      - conditions:
          - condition: template
            value_template: >-
              {{ states('sensor.battery_charge_discharge_power')|float(0) >= 0
        sequence:
          - service: input_number.set_value
              value: >
                {% set total_loss =
                states('sensor.inverter_efficiency_loss_daily')|float(0) %} {%
                set bat_out_loss =
                states('input_number.battery_discharge_loss')|float(0)
                %}          {{ total_loss - bat_out_loss }}
              entity_id: input_number.battery_charge_loss
      - conditions:
            value_template: "{{ states('sensor.battery_charge_discharge_power')|float(0) < 0 }}"
        sequence:
              value: >
                {% set total_loss =
                set bat_in_loss =
                states('input_number.battery_charge_loss')|float(0) %}
                {{ total_loss - bat_in_loss }}
              entity_id: input_number.battery_discharge_loss
mode: single
If I reload the related Integration the state from sensor.inverter_efficiency_loss_daily is going into “unavailable” and therefore below trigger should not be triggered
  - platform: state
    not_from:
      - unknown
      - unavailable
But the first sequence is fired and is disturbing my input_number.battery_discharge_loss.
Before the reload:
During the reload:
Any ideas in which way to prevend?
  - platform: state
    not_from:
      - unknown
      - unavailable
    not_to:
      - unknown
      - unavailable
Amazing - It works now as expected!
Many thanks!!!
