Hi there, i hope someone can help me. I have several automations that won’t work and i tried to troubleshoot them. I think it is because of something wrong with the timing.
for example, i have two different blueprints imported to send me a notification when my garbage is picked-up. This are westenberg/garbage-reminder.yaml and idominiki/GarbageCollection.yaml.
Both will check the garbage entities and if there is 1 day before pick up they must sent a notification through telegram. If i do a test it works, but when the blueprints must send a message on a certain time i get Stopped because a condition failed.
I think it has something to do with an invalid strftime date format.
I one of the automations i can set the correct strftime, which is by default %Y-%m-%d, in the configuration yaml of the garbage addon it is also set to %Y-%m-%d.
But when i check the entities, i see several different time/date fields.
I get in the yaml status attributes: Sort_date: 20221101
In the status date: Tomorrow, 2022-10-21
And if i check the attributes of an entity in lovelace i get also Sort date: 20.221.021 (this one is strange, but can be default behavior).
Maybe someone else has have the same problem in the past en seems to solve it?
