Automation switch on entity only between hours
I am newbee to HA automation.
I would like to switch on an entity between 2:00 and 4:00 AM. The rest of the day it shall be switched off!
I saw examples with "condition: time; after; before. But I think I would need some trigger for this as well.
I could set two automations! One for switch “on” and one for switch “off”.
If this would be the solution - mmmh - fine! But I hope there is some better setup for my requirement.
Any help apreciated!
Yes two automations with a time trigger in each, 2:00 for on and 4:00 for off is the easiest way. There are many ways to combine the two automations into one but it is best to start out simple.
Other ways you could do this in one automation:
  1. Use a schedule helper. Edit the schedule helper to cover the 2am to 4am time. Then:
 - platform: state
   entity_id: schedule.my_switch_schedule
   not_to:
    - unavailable
    - unknown
  - if:
      - condition: state
        state: 'on'
    then:
      - service: switch.turn_on
          entity_id: switch.my_switch
    else:
      - service: switch.turn_off
  1. Or using trigger ids, templates and time triggers:
  - id: 'on'
    platform: time
    at: "02:00:00"
  - id: 'off'
    platform: time
    at: "04:00:00"
  - service: "switch.turn_{{ trigger_id }}"
There are other ways as well but try to walk before you try to fly.
thanks for the examples.
I tried 2) but I get “Fehler: Template rendered invalid service: switch.turn_”
- id: '1720157995030'
  alias: Test
  description: ''
  - id: 'on'
    platform: time
    at: 09:07:00
  - id: 'off'
    platform: time
    at: 09:08:00
  - service: switch.turn_{{ trigger_id }}
    metadata: {}
    data: {}
      entity_id: switch.s_shelly02_switch_0
  mode: single
Typo. Should be:
  - service: switch.turn_{{ trigger.id }}
…and it’s recommended to put your times in quotes:
    at: "09:07:00"
I have tried to add a schedule helper 1:1 from the example of the doc but failed:
At least, the helper does not show up in the webgui.
schedule:
  thermostat_schedule:
    name: "Thermostat schedule"
    monday:
        to: "21:00:00"
    tuesday:
        to: "21:00:00"
    wednesday:
        to: "21:00:00"
    thursday:
        to: "21:00:00"
    friday:
        to: "23:00:00"
    saturday:
        to: "10:00:00"
        to: "23:00:00"
    sunday:
        to: "21:00:00"
default_config:
exists in my configuration.yaml
what can I do the schedule to show up in the weggui?
You have to create it via the UI for it to show up:
what type of helper is it?
In my webgui e.g. “timetable” (I guess it could be timetable) is greyed out
Schedule in English: look for the same icon:
You should be able to see but not edit schedules created via YAML:
Have you fully restarted HA since adding the schedule to the YAML? Any errors in the logs?
OK
  1. “schedule:” still had to be in the yaml
  2. available after restart - not when reloading config only!
Now I can create a schedule and see it in the gui.
Thanks!
You can reload config from now on — but you need a full restart after adding a new integration to your YAML for the first time.
