Automation switch on if a value falls below or if value rises again
I can not get on with a automatisin and ask for help.
I have hass.io running on a synology nas, version 0.192.
In the configuraion.yaml the automations.yaml is called:
 # Automation
The following automation works good, but I would like to have the two in one - how do you do that?
- id: '1572282030760'
  alias: moisture-detection-on
  - below: '650'
    entity_id: sensor.wemosd1_14_feuchte
    platform: numeric_state
  - service: homeassistant.turn_on
    entity_id: switch.wemosd1_13_swi
- id: '1572282030761'
  alias: moisture-detection-off
  - above: '500'
  - service: homeassistant.turn_off
You could move the second trigger to the first automation and use a service template to decide which service to call. So you’d want something like this:
  alias: moisture-detection-on-off
  - below: '650'
  - above: '500'
  - service_template: >
      {% if states('sensor.wemosd1_14_feuchte') | float < 650 %}
      {% else %}
      {% endif %}
Edit: Nope, wouldn’t work. I was thinking above 650, not below. The template would evaluate as true if either trigger happens :man_facepalming:
You’d be better setting up a binary switch that had this hysteresis set and then run from that.
Edit: OR you could just use Tediore’s solution above :smiley:
Close. For a numeric state trigger you can look at the trigger variable’s above and below values. If an above trigger fired, then above will have a value and below will be None, and vice versa. So:
  - below: '650'
  - above: '500'
      {% if trigger.below %}
      {% else %}
      {% endif %}
Ah awesome, thank you.
Thanks for the help :beers:
My solution:
  - below: '600'
  - above: '600'
      {% else %}
      {% endif %}
Changed the values below and above, because i believe that the first values are not logical.
In addition, I’ve even created a binary_sensor to play with different ways of evaluation and automation:
  - platform: mqtt
    state_topic: "tele/wemosd1_14/SENSOR"
    value_template:
      "{% if value_json['ANALOG'].A0 | float < 600 %}
        ON
      {% else %}
        OFF
      {% endif %}"
    device_class: moisture
Postscript:
The sensor provides a dry value of about 730 and about 300 dipped in water. In potting soil (normally moist) it delivers about 600.
Thought is the whole as a rain sensor to close possibly open roof window - with the current limit value 600, I’ll probably still have to play
