I had several garage automations that used the switch position to trigger. Recently they all stopped working. It looks like synonyms are no longer being used? I was using on / off based on old directions. I needed to changed the automations to open / closed to make it work. I had thought (from old documentation) that off, closed would work the same. Did this get changed?
