Hi All,
I’m a bit puzzled why the Automation switch keeps on switching itself off? Every time I log in I switch it one and then it turns itself off.??
My assumption is this switch controls whether any automation will run, is this correct?
Hi All,
This appears to be an issue at present. The Group toggle does not determine if the Automation will run. Instead, the toggle next to the name of the Automation will determine that.
