Sorry for the generic title, not sure how else to summarize this.
I built a python script on a device on my network that sits behind a VPN. The python script calls my HA instance and updates an entity called vpn_ip. I put this in crontab and it runs every few minutes. When HA first starts, I set this value to unknown, and then on the next crontab run, it should update to the external IP address (I’m calling https://api.ipify.org?format=json in that script and it should respond back with the IP). If the vpn device cannot talk to the internet (ie - the VPN went down), the request will timeout, the VPN device then updates HA with a value of TIMEOUT. I have an automation (that works), which uses pushbullet to send a push if the status changes to TIMEOUT. I’m now trying to build a basic binary sensor that will show on/ or for the vpn status. I came up with this, but it’s not changing the status of the binary_sensor at all:
- id: '1573837112220'
alias: VPN Up
description: ''
- entity_id: sensor.vpn_ip
platform: state
condition: []
- condition: state
entity_id: binary_sensor.vpn_status
state: >-
if
is_state('sensor.vpn_ip','unknown') or is_state('sensor.vpn_ip','TIMEOUT') or is_state('sensor.vpn_ip','URL_ERROR')
true
{% else %}
false
{% endif %}'
I did the opposite on my existing automation (to: TIMEOUT), by adding a second action after the pushbullet call, but that isn’t working either. I’m not entirely sure what I have wrong, but I assume it’s in the state: element.
Thanks!
