I’m new to home automation and I’m trying to create an automation to turn on a power point if the Outdoor temperature is higher than the temperature in my outdoor fish tank.
If I check the template trigger in the Developer Tools it reports True so I have no idea why it’s not actually triggering
This is the automation I’ve created, any thoughts would be greatly appreciated
Template triggers work by evaluating a template when any of the recognized entities change state. The trigger will fire if the state change caused the template to render ‘true’ when it was previously ‘false’.
If your template already renders “true” when you save/initialize the automation, it will not cause the actions to be executed. Triggering require the template’s rendered value to change from “false” to “true”.
Are you sure… it’s still in the copy you pasted the second time.
I don’t see any other glaring issues. The only other thing that comes to mind would be to make sure the hvac mode of the climate entity is properly set.
