Sorry @AhmadK I donât understand your answer?
All lines below this one:
service_template: >-
are determining the service to assign to service_template
. Whatever the result, it must be one valid service.
In this line, you are attempting to assign it two services and Home Assistant rejected it.
script.kitchen_light_dimm_on, script.kitchen_light_moon
Thatâs probably because youâre yet to read the link provided.
And @123 already explained you the main reason of your error.
Does it work now?
Pretty good yes.
I donât know if it possible to make configuration shorter, but works for me:
scripts:
## IR KITCHEN LIGHT REMOTE BUTTONS
kitchen_light_sun:
- service: switch.turn_on
entity_id: switch.kitchen_light_on_off
- delay:
milliseconds: 10
- service: switch.broadlink_send_packet_192_168_2_1
packet:
- "JgBUAAABJZITEhI3EhISEhI3EjcSEhI3EjcSEhI3EjcSEhMREzYTERMREzYTNhM2ExETERM2EzYTNhMRExISEhI3EjcSEhISEgAFJgABJUYTAAWLFwANBQAAAAA="
- service: mqtt.publish
topic: 'home/buttons/ir'
payload: 'kitchen_light_sun'
- delay: '00:00:02'
payload: 'none'
kitchen_light_moon:
- service: automation.turn_off
entity_id: automation.kitchen_light_daytime
- service: automation.turn_on
- delay:
milliseconds: 10
packet:
- "JgBQAAABJJQRExE4ERMRExI3EjcSEhI3EjcSEhI3EjcSEhISEjcSEhISEhISExETERMRExETETgROBE4ETgROBE4ETgROBETEgAFJgABJEcSAA0FAAAAAAAAAAA="
payload: 'kitchen_light_moon'
- delay: '00:00:02'
payload: 'none'
kitchen_light_dimm_up:
packet:
- "JgBQAAABKJMSEhI3EhISExE4ETgRExE4ETgRExE4ETgRExETEjcSEhISEjcSEhI3EhIUEBQ1FDUUNRQQFDUUEBQ1FDUUEBQREwAFJAABKEQUAA0FAAAAAAAAAAA="
kitchen_light_dimm_down:
packet:
- "JgBQAAABJpIUEBQ1FBAUEBQ1FDUUEBQ1FDUUEBQ1EzYUERISEjcSEhISEjYTEhMREzYTERM2EzYTNhMREzYTNhMREzYTERMREwAFJQABJ0UUAA0FAAAAAAAAAAA="
kitchen_light_ct_up:
packet:
- "JgBQAAABJpIUEBQ1FBAUEBQ1FDUUERM1FDUUERQ1FDUUEBQQFDUUEBQ1FBAUEBQ1FDUUEBQQFDUUEBQ1FDUUEBQQFDUUNRQQFAAFJAABJ0UUAA0FAAAAAAAAAAA="
kitchen_light_ct_down:
packet:
- "JgBQAAABJ5EUEBQ1FBAUEBQ1FDUUERM1FDUVEBQ1FDUUEBQQFDUUEBQ1FBAUEBQQFBAUEBQ1FDUUEBQ1FDUUNRQ1FDUUERMRFAAFJAABJ0QUAA0FAAAAAAAAAAA="
kitchen_light_on:
packet:
- "JgBQAAABJZMSExE3EhMRExE4ETgRExE4ETgRExI3EjcSEhISEjcSEhISEjcSEhISEhISExETETgRNhMTETgROBE4ETgROBETEgAFJgABJUYSAA0FAAAAAAAAAAA="
kitchen_light_off:
- service: script.toggle
entity_id: script.kitchen_light_ct_down_10x
packet:
- "JgBQAAABJpITERM2ExESEhM2EzYTERM2EzYTERM2EjcTERMSEjcSEhETERMROBI3EjcSEhI3EjcSNxI3EhISEhISEjcTERMREgAFJgABJUYSAA0FAAAAAAAAAAA="
- service: switch.turn_off
kitchen_light_dimm_up_2x:
entity_id: script.kitchen_light_dimm_up
kitchen_light_dimm_down_2x:
entity_id: script.kitchen_light_dimm_down
kitchen_light_dimm_up_3x:
kitchen_light_dimm_down_3x:
kitchen_light_dimm_up_4x:
kitchen_light_dimm_down_4x:
kitchen_light_dimm_up_5x:
kitchen_light_dimm_down_5x:
kitchen_light_dimm_up_6x:
kitchen_light_dimm_down_6x:
kitchen_light_dimm_up_7x:
kitchen_light_dimm_down_7x:
kitchen_light_ct_up_2x:
entity_id: script.kitchen_light_ct_up
kitchen_light_ct_down_2x:
kitchen_light_ct_up_3x:
kitchen_light_ct_down_3x:
kitchen_light_ct_up_4x:
kitchen_light_ct_down_4x:
kitchen_light_ct_up_5x:
kitchen_light_ct_down_5x:
kitchen_light_ct_up_6x:
kitchen_light_ct_down_6x:
kitchen_light_ct_up_7x:
kitchen_light_ct_down_7x:
kitchen_light_ct_up_8x:
kitchen_light_ct_down_8x:
kitchen_light_ct_up_9x:
kitchen_light_ct_down_9x:
kitchen_light_ct_up_10x:
kitchen_light_ct_down_10x:
## SCRIPT DO NOTHING
do_nothing:
topic: 'home/status/'
payload: 'script_do_nothing'
automation:
# SET DIMM to 10
- alias: 'kitchen_set_moon_mode'
platform: state
entity_id: sensor.mqtt_ir_button_sensing
to: 'kitchen_light_moon'
data_template:
entity_id: input_number.kitchen_light_dimm
value: 10
# SET DIMM to 100
- alias: 'kitchen_light_set_sun_mode'
platform: state
to: 'kitchen_light_sun'
data_template:
value: 100
# WHEN OFF SET DIMM and CT to 0
- alias: 'kitchen_light_off_set_dimm_ct_0'
platform: state
entity_id: switch.ir_kitchen_light
to: 'off'
data_template:
value: 0
data_template:
entity_id: input_number.kitchen_light_ct
value: 0
# WHEN ON RESET CT
- alias: 'kitchen_light_on_reset_ct'
platform: state
to: 'on'
data_template:
value: 100
# WHEN ON SENSING DAYTIME AND TURN ON LIGHT 10% OR 100%
- alias: 'kitchen_light_daytime'
platform: state
{% set sun = states('sun.sun') %}
{% set light = states('switch.ir_kitchen_light') %}
{% set slider = states('input_number.kitchen_light_dimm') | round(0) %}
{% if sun == 'above_horizon' and light == 'on' and slider == 0 %}
script.kitchen_light_sun
{% elif sun == 'below_horizon' and light == 'on' and slider == 0 %}
script.do_nothing
{% endif -%}
# SET DIMM
- alias: 'kitchen_light_set_dimm'
platform: state
{% set to = trigger.to_state.state | int %}
{% set from = trigger.from_state.state | int %}
{% set diff = (from - to) | round(0) %}
{% set step = diff / 10 | round(0) %}
{% if slider == 0 %}
script.kitchen_light_off
{% elif slider == 10 %}
{% elif slider == 100 %}
{% elif diff < 0 and step == -1 %}
{% elif diff > 0 and step == 1 %}
{% elif diff < 0 and step == -2 %}
script.kitchen_light_dimm_up_2x
{% elif diff > 0 and step == 2 %}
script.kitchen_light_dimm_down_2x
{% elif diff < 0 and step == -3 %}
script.kitchen_light_dimm_up_3x
{% elif diff > 0 and step == 3 %}
script.kitchen_light_dimm_down_3x
{% elif diff < 0 and step == -4 %}
script.kitchen_light_dimm_up_4x
{% elif diff > 0 and step == 4 %}
script.kitchen_light_dimm_down_4x
{% elif diff < 0 and step == -5 %}
script.kitchen_light_dimm_up_5x
{% elif diff > 0 and step == 5 %}
script.kitchen_light_dimm_down_5x
{% elif diff < 0 and step == -6 %}
script.kitchen_light_dimm_up_6x
{% elif diff > 0 and step == 6 %}
script.kitchen_light_dimm_down_6x
{% elif diff < 0 and step == -7 %}
script.kitchen_light_dimm_up_7x
{% elif diff > 0 and step == 7 %}
script.kitchen_light_dimm_down_7x
script.do_nothing
{% endif -%}
# SET CT
- alias: 'kitchen_light_set_ct'
platform: state
{% set slider = states('input_number.kitchen_light_ct') | round(0) %}
{% if diff < 0 and step == -1 %}
script.kitchen_light_ct_down_2x
script.kitchen_light_ct_up_2x
script.kitchen_light_ct_down_3x
script.kitchen_light_ct_up_3x
script.kitchen_light_ct_down_4x
script.kitchen_light_ct_up_4x
script.kitchen_light_ct_down_5x
script.kitchen_light_ct_up_5x
script.kitchen_light_ct_down_6x
script.kitchen_light_ct_up_6x
script.kitchen_light_ct_down_7x
script.kitchen_light_ct_up_7x
{% elif diff < 0 and step == -8 %}
script.kitchen_light_ct_down_8x
{% elif diff > 0 and step == 8 %}
script.kitchen_light_ct_up_8x
{% elif diff < 0 and step == -9 %}
script.kitchen_light_ct_down_9x
{% elif diff > 0 and step == 9 %}
script.kitchen_light_ct_up_9x
{% elif diff < 0 and step == -10 %}
{% elif diff > 0 and step == 10 %}
script.kitchen_light_ct_up_10x
script.do_nothing
{% endif -%}
not having read your complete configuration, you might be interested in the ultimate script.dummy. Since youâre using an mqtt.publish service actually publishing a payload, you might find it useful:
dummy:
alias: 'Dummy script'
delay: 00:00:00
define it globally in your scripts file, and use it in any place needed.
I donât understand? Why dummy script is useful?
because itâs the ultimate do-nothing script. You can call it in templates, like you do, and have it do nothing.
OK, thanks.
I would use a python_script to replace all of the scripts (up_1X, down 1X, up_2X, down_2X, etc).
The automationâs template wouldnât change much but now it would simply calculate the number of repetitions to pass on to the python_script. For example, repetitions: -7
would instruct the python_script.brightness_controller
to transmit a dim command 7 times. Repetitions=0 would mean to simply turn the light off.
- service: python_script.brightness_controller
data_template:
repetitions: `<your template>`
However, if what you created works for you, then I wouldnât bother with a python_script (unless you wanted to learn something new).
Thanks @123. I am always open to learn something new if you have a time to explain more detail what you have in mind.
Iâm kind late to the topic but just to add a idea. Instead of trying to keep the state of device, why not just bring it to a initial know state and then set the new state from there? If I got it right, when you press the âmoon buttonâ the brightness goes to 10%, so after pressing it you know the state, then you just have to send N-1 âdimm_upâ commands to match the brightness to your input slider value. It may or may not be a little disturbing for the people in the room when the brightness goes to 10%âŚ
Here is an example of a python_script that accepts one parameter (command
) that specifies the number of times to transmit dimm_up or dimm_down.
This python_script accepts a command
in the range from -10 to 11.
If command
is:
- -5 the python_script will send dimm_down 5 times to the light.
- 3 will send dimm_up 3 times to the light.
- 0 means to turn off the light.
- 11 means to turn on the light.
To permit Home Assistant to support python_scripts, you must add the following line to configuration.yaml
python_script:
In your config directory, create a sub-directory called python_scripts
then create a new file in it called dimm_control.py
containing the following python code:
rf = { "ON":"JgBQAAABJZMSExE3EhMRExE4ETgRExE4ETgRExI3EjcSEhISEjcSEhISEjcSEhISEhISExETETgRNhMTETgROBE4ETgROBETEgAFJgABJUYSAA0FAAAAAAAAAAA=",
"OFF":"JgBQAAABJpITERM2ExESEhM2EzYTERM2EzYTERM2EjcTERMSEjcSEhETERMROBI3EjcSEhI3EjcSNxI3EhISEhISEjcTERMREgAFJgABJUYSAA0FAAAAAAAAAAA=",
"UP":"JgBQAAABKJMSEhI3EhISExE4ETgRExE4ETgRExE4ETgRExETEjcSEhISEjcSEhI3EhIUEBQ1FDUUNRQQFDUUEBQ1FDUUEBQREwAFJAABKEQUAA0FAAAAAAAAAAA=",
"DOWN":"JgBQAAABJpIUEBQ1FBAUEBQ1FDUUEBQ1FDUUEBQ1EzYUERISEjcSEhISEjYTEhMREzYTERM2EzYTNhMREzYTNhMREzYTERMREwAFJQABJ0UUAA0FAAAAAAAAAAA="
cmd = data.get('command')
if cmd is not None:
cmd = int(cmd)
if -10 <= cmd <= 11:
if cmd == 0:
loop = 1
rfc = rf['OFF']
elif cmd == 11:
loop = 1
rfc = rf['ON']
else:
if cmd > 0:
rfc = rf['UP']
else:
rfc = rf['DOWN']
loop = abs(cmd)
service_data = {'packet':'{}'.format(rfc)}
for i in range(loop):
hass.services.call('switch', 'broadlink_send_packet_192_168_2_1', service_data, False)
Now restart Home Assistant.
To test it:
- Go to Home Assistantâs Services page
- Set Service to
python_script.dimm_control
- To turn the light on, set Service Data to
{"command":11}
- click the CALL SERVICE button
To dimm the light down 2 steps, set Service Data to {"command":-2}
and click CALL SERVICE.
To use it in an automation, call the service python_script.dimm_control
and use a data_template
to set command
to a value between -10 and 11. For example:
platform: state
service: python_script.dimm_control
data_template:
command: >-
0
11
{{step}}
⌠and if it doesnât work, oh well.
Thanks for script @123
I try today but there is something wrong with python script.
Here is an error:
Error executing script: (ServiceNotFound(...), 'Service switch.broadlink_send_packet_192_168_2_1 not found')
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/python_script/__init__.py", line 159, in execute
exec(compiled.code, restricted_globals, local)
File "dimm_control.py", line 27, in <module>
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1082, in call
self._hass.loop
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 432, in result
return self.__get_result()
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 384, in __get_result
raise self._exception
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1115, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: (ServiceNotFound(...), 'Service switch.broadlink_send_packet_192_168_2_1 not found')
I have only service called broadlink.send?
Look at the code in your script, shown in this post.
kitchen_light_sun:
- delay:
milliseconds: 10
packet:
It uses service: switch.broadlink_send_packet_192_168_2_1
which is the same one used in the python_script.
If you recently upgraded Home Assistant to 0.92 then it has a new Broadlink component with a completely different service: broadlink.send
. As a result, everywhere you have used service: switch.broadlink_send_packet_192_168_2_1
will no longer work.
Yes I recently upgraded to 0.92.1.
If I understand I must adjust python script to work with new broadlink component. How?
this:
to this: ???
hass.services.call('broadlink', 'send', service_data, False)
Yes, but the contents of service_data
will now have to specify the host
service_data = {'host':'192.168.2.1', 'packet':'{}'.format(rfc)}
Your original scripts will also have to change because they still use switch.broadlink_send_packet_192_168_2_1
If I understand correctly I must change:
this:
to this:
