I am still feeling my way around templating syntax, both in sensor configurations and in automations. My current issue is with the following automation:
This snippet of code works fine:
- id: '1605906216340'
alias: 'set test max temp '
description: ''
- platform: state
entity_id: input_boolean.test_button
to: 'on'
condition: []
- service: input_number.set_value
value: 77
entity_id: input_number.test_max_temp
mode: single
while this does not:
description: ''
- platform: state
to: 'on'
condition: []
value_template: "{{ states('input_number.test_number')|int }}"
mode: single
At least this passes the config test, but it does not function.
If I remove the quote marks from the value_template, thinking that it is considering it all a string, then the config check fails.
What am I missing? TIA.
