Automation Templating Using Weekdays
I want to be able to use templates to condition whether its a weekday and before a certain time. What I am looking for is:
If its a weekday and before 00:00, lights on, else if on a weekend before 02:00, else lights off.
Here is my automation so far:
- action:
  - alias: Turn on lights/switches without presence detection
    data_template:
      entity_id: group.outside
    service_template: >
      {% if states('sensor.sn1_ldr') | float >= 630 %}
        homeassistant.turn_off
      {% else %}
        {% IF WEEKDAY AND BEFORE MIDNIGHT %}
          homeassistant.turn_on
        {% else %}
          {% IF BEFORE 2am %}
          {% else %}
          {% endif %}
        {% endif %}
      {% endif %}
  alias: Turn on/off other lights/switches
  condition:
  - after: '13:00:00'
    before: '06:00:00'
    condition: time
  - above: '630'
    entity_id: sensor.sn1_ldr
    platform: numeric_state
  - below: '630'
I’m not sure what you’re trying to do, but it’s possible that a simple OR condition would help, combined with a time condition.
Also, the time condition allows you to specify days, which might further help.
OK, well a couple of points…
There is no time that is less than 0 on any given day. Any time before 0 is yesterday.
Also, your code apparently does something quite different from your stated problem.
SO… I chose to implement your stated problem as a starting point for you.
Note : I included the (hour < 0) requirement even though we know that is not possible.
SO here is the template :
{% set curhour=now().hour%}
{% set wdFlag = now().weekday() in (0,1,2,3,4)%}
{% if wdFlag %}
   {### weekday ###}
    {%if curhour < 0 %}
       light.turn_on
    {% else %}
       light.turn_off
    {% endif %}
{%else%}
    {### weekend ###}
    {% if curhour < 2 %}
        light.turn_on
   {% else %}
        light.turn_off
    {% endif %}
{% endif %}
Would this work?
{% set curhour = now().hour %}
{% if now().weekday() in (0,1,2,3,4) %}
  {% if curhour <= 23 or curhour >= 13 %}
  {% else %}
  {% endif %}
{% else %}
  {% if curhour <= 2 or curhour >= 13 %}
  {% else %}
  {% endif %}
{% endif %}
I think I have the signs matched up and the syntax looks ok I think…
You have a line that says:
{% if curhour >= 23 or curhour >= 13 %}
when curhour >= 23 it will always be > 13 so this is equivalent to
{% if curhour >= 13 %}
I had the sign backwards, see edit
That’s worse.
Every hour is either <= 23 or >= 13
Perhaps you meant <=23 AND >= 13
OK so,
  {% if curhour <= 23 and curhour >= 13 %}
  {% else %}
  {% endif %}
{% else %}
  {% else %}
  {% endif %}
{% endif %}
This will work?
I just realised this would not trigger until light level changes. I have added another trigger to check at 1 minute past every hour:
- action:
    data_template:
    service_template: >
      {% else %}
          {% else %}
          {% endif %}
        {% else %}
          {% else %}
          {% endif %}
        {% endif %}
      {% endif %}
  condition:
  - after: '13:00:00'
    before: '06:00:00'
    condition: time
  - above: '630'
  - below: '630'
  - platform: time
    minutes: 1
    seconds: 00
I’m very very confused about what you’re trying to do. I think that if you say in plain english what you want to do (e.g. turn off the lights if it’s this way, turn them off if it’s that way), someone might be able to make this automation much more simple and robust. :slight_smile:
Why not just have two automations, one to turn on the group when certain conditions are met, and another to turn it off when certain conditions are met? You could combine conditions with an “or” condition.
I like using templates, but this just strikes me as a nightmare to debug.
You should see my other automation for my indoor lights and switches: :smiley:
- action:
  - alias: Setee light
    data_template:
      entity_id: light.setee_light
      kelvin: 3000
      brightness_pct: >
          0
        {% elif states('sensor.sn1_ldr') | float >= 450 %}
          60
        {% elif states('sensor.sn1_ldr') | float >= 280 %}
          70
        {% else %}
          80
        {% endif %}
    service: light.turn_on
  - alias: PC lights
    data_template:
      entity_id: light.pc_light
      kelvin: 3000
      brightness_pct: >
        {% if is_state('switch.pc', 'on') %}
          2
        {% elif states('sensor.sn1_ldr') | float >= 630 %}
          0
          15
          20
        {% else %}
          25
        {% endif %}
  # Xmas
  - alias: Xmas lights (Inside)
    data_template:
      entity_id: group.xmas_lights
    service_template: >
      {% else %}
      {% endif %}
  alias: Lights
  condition:
  - condition: state
    entity_id: group.phones
    state: home
  - after: '13:00:00'
    before: '06:00:00'
    condition: time
  - above: '630'
  - above: '450'
    below: '630'
  - above: '280'
    below: '450'
  - below: '280'
  - entity_id: switch.pc
    platform: state
    to: 'on'
    platform: state
    to: 'off'
  - platform: event
    event_type: call_service
    event_data:
      service_data:
        entity_id: scene.reset_lights
      domain: scene
      service: turn_on
  - event: start
    platform: homeassistant
This conditions against my pc being on, light level on my window sensor with a gradual increase of the living room bulbs and is triggered by my pc, light level, startup etc.
You’re a monster. :stuck_out_tongue:
