I have a fairly large home assistant set-up with around 130 Lutron Caseta dimmers (Split across two hubs / accounts).
I want to create an automation (and preferably a blueprint to go with it) that changes what brightness the lights will turn on to the next time the are turned on based on time of day.
I have an automation that changes the value of a helper “input_number.auto_brightness” to a different value at different times of day:
12am-5am: 10
5am-7am: 40
7am-9am: 60
9am-4pm: 100
4pm-6pm: 70
6pm-8pm: 50
8pm-9pm: 40
9pm-12pm: 20
I want to make it so that when a light is turned on, either from some other automation or from a physical switch/dimmer, they will turn on with the brightness value of “input_number.auto_brightness”.
I am pretty used to setting up automations that turn lights on to certain brightnesses but it has to turn them on to do so.
If you have the automation trigger on the light being turned on then depending on the light it might work.
If there is a fade setting on the light itself then turn that on and it will give you a better chance
