I have a bathroom fan that comes on if the humidity is above 69%, and turns off when below 56%.
The only problem is if the fan is manually triggered and the humidity is already under 56%. The bottom 40% trigger is there to solve this problem. It works almost all the time, except if it is very dry winter time.
Is there a better approach besides setting a secondary, lower value to trigger?
I know I can calculate the average of other entities, all the humidity sensors in the house, let’s call it h
. I would like to set the trigger to say h+5
. So, the automation is triggered f the bathroom humidity crosses (average house humidity+5)%
How would I do this?
alias: "-Base: bath: Fan: ON/OFF on humidity"
description: Turn on fan if too humid, off if okay in basement bath.
- platform: numeric_state
entity_id: sensor.weathersensor5_humidity
above: 69
entity_id:
- sensor.weathersensor5_humidity
below: 56
entity_id:
below: 40
condition: []
- choose:
- conditions:
- condition: numeric_state
above: 69
sequence:
- type: turn_on
device_id: eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
entity_id: ffffffffffffffffffffffffffffffff
domain: switch
- conditions:
below: 56
sequence:
- type: turn_off
domain: switch
mode: single
