I have an automation that turns my thermostat off for one hour then turns it back on (I need a failsafe incase this very thing happens in any way). For some reason even when HASS is running fine part of this automation doesn’t fire? It’s strange. To be clear this works 90% of the time. Here is the automation.
- alias: 'Thermostat - Open the windows'
value_template: '{{ states.sensor.dark_sky_wind_speed.state|float > 4 }}'
condition:
condition: and
conditions:
- condition: template
value_template: '{{ (states.sensor.bedroom_temperature.state|float + states.sensor.thermostat_temperature.state|float) / 2 > 74 }}'
- condition: state
entity_id: group.people
state: 'home'
- condition: or
conditions:
value_template: '{{ (states.sensor.thermostat_temperature.state|float - states.sensor.dark_sky_temperature.state|float) >= 3 }}'
value_template: '{{ (states.sensor.bedroom_temperature.state|float - states.sensor.dark_sky_temperature.state|float) >= 3 }}'
- service: notify.pushbullet
data_template:
- device/Galaxy S7
- email/*******@gmail.com
- email/**********@gmail.com
message: >
It's cold enough outside to turn off the AC, so open some windows!
It's {{ states('sensor.thermostat_temperature') }} degrees in the house and {{ states('sensor.bedroom_temperature') }} in the bedroom.
Outside it's {{ states('sensor.dark_sky_temperature') }} degrees with {{ states('sensor.lateral_wind_direction') }} wind @ {{ states('sensor.dark_sky_wind_speed') }} mph.
- service: notify.kitchen_tablet
data_template:
message: >
It's {{ states('sensor.thermostat_temperature')|round|int }} degrees in the house and {{ states('sensor.bedroom_temperature')|round|int }} in the bedroom.
Outside it's {{ states('sensor.dark_sky_temperature')|round|int }} degrees with {{ states('sensor.lateral_wind_direction') }} wind @ {{ states('sensor.dark_sky_wind_speed')|round|int }} mile per hour.
- service: input_select.select_option
entity_id: input_select.thermo_hvac
option: 'Off'
- service: homeassistant.turn_off
entity_id: automation.just_open_the_damn_windows
- delay:
hours: 1
- service: homeassistant.turn_on
option: 'Auto'
data_template:
- device/Galaxy S7
- email/******@gmail.com
- email/*********@gmail.com
message: >
I'm turning the Thermostat back to Auto
So the issue is at least this time, that the automation was turned back on but not the thermostat. Could this be an API call issue? I have been getting the following error since .48.1…
`[pyecobee] Error connecting to Ecobee while attempting to get thermostat data. Refreshing tokens and trying again.
Could that have something to do with it maybe? My ecobee occupancy sensors are back now with this update so there’s that. Any insight would be appreciated.
