I set up a Fire HD Tablet with Fully Kiosk as a Dashboard.
I would like to change the profile’s mode to DARK when the sun goes down and LIGHT when the sun is up.
The AUTO mode does not work as it triggers only when the system on it runs dark mode as well. Unfortunately, the Fire HD Tablet has no Dark mode.
I wanted to do it with automation, but it doesn’t work.
I did the following, it runs without error, but it does not change the Theme to dark:
alias: auto dark
description: “”
platform: state
entity_id:
sun.sun
service: frontend.set_theme
mode: dark
mode: single
Does anybody have a solution to change the Theme mode to dark every evening and back to light in the morning?
I replicated it, but unfortunately, it didn’t work.
It runs until the end but does not change the Theme, either for the TAB or the client in a browser.
I changed the Theme to “Backend Selected”
In the Developer Tools, nothing happens when i try to run the “frontend.set_theme” service.
Running the frontend.set_theme in the Services tool does work for me. I don’t use minimalist-mobile so that may be the source of your issue. The name value is case-sensitive, so make sure you are using capitals where appropriate.
I’m not 100% sure what you are saying here… If you have set a Dashboard View to a specific theme, that will override the global theme set by the service call.
