I am wanting to create a script or automation that when called, updates an input text entity with a name from a list. Each time the automation is called, I want it to update the input text with the next item on the list. The list will be 5 pre-defined names, however I also need to be able to temporarily remove names from the list using the front end. Big off/on buttons or tick boxes would be best.
My goal is to create a chore roster for my family of five. For five nights of the week we have a designated night to cook/clean. This has been easy to set up in HASS. But for two of the nights, we take it in turns. Previously I had written out this cycle on a calendar, but often a family member will be gone for a few weeks and the cycle is wrong. I need HASS to only cycle through the family members available.
I asked ChatGPT how to do this but its script contains functions that do not exist in HASS. Transcript
Is this a job for someone on Toptal, Fiverr or Upwork?
One way to do this would be to create a set of helpers; one Input boolean for each person and an Input select that has all the names from the booleans. This can be done in the UI or via yaml configuration.
input_boolean:
person_a_chore_availability:
person_b_chore_availability:
person_c_chore_availability:
person_d_chore_availability:
person_e_chore_availability:
input_select:
chore_1:
name: Who does chore 1 today
options:
- Person A
- Person B
- Person C
- Person D
- Person E
Then create a script to cycle through:
alias: Next Option Until Available
sequence:
- repeat:
until:
- condition: template
value_template: >-
{% set available =
expand('input_boolean.person_a_chore_availability',
'input_boolean.person_b_chore_availability',
'input_boolean.person_c_chore_availability',
'input_boolean.person_d_chore_availability',
'input_boolean.person_e_chore_availability')
| selectattr('state', 'eq', 'on') | map(attribute='name')
| list %}
{{ states('input_select.chore_1') in available}}
sequence:
- service: input_select.select_next
data: {}
entity_id: input_select.chore_1
mode: single
Here is a basic Entities card to demonstrate:
type: entities
entities:
- entity: input_boolean.person_a_chore_availability
- entity: input_boolean.person_b_chore_availability
- entity: input_boolean.person_c_chore_availability
- entity: input_boolean.person_d_chore_availability
- entity: input_boolean.person_e_chore_availability
- entity: input_select.chore_1
- entity: script.next_option_until_available
Hi Drew, thank you so much. This worked perfectly.
