Automation to force current Nest thermostat setting back to existing schedule
Some people in my household sometimes change the setting temporarily on one of our Nest thermostats but ‘forget’ to return it back to the original setting when the leave the room.
I would like to create an automation that regularly polls the thermostat to see if the current set temperature is equal to the schedule temperature… and if not, then resume schedule.
This is analogous to releasing what used to be called a Hold temperature on older thermostats.
Said another way, is there any way to get access to the actual scheduled temperature from HA? Is it stored in any of the atrributes?
