I have Tuya smart siren called Neo NAS-AB02
. It is recognized by Zigbee in HA and has ID TS0601 by _TZE204_t1blo2bj
I bought it from Aliexpress, unfortunately when you buy it, you can not see the exact model. And my model does not have support to change volume and melody within HA.
However, it is possible, but manually. You go to device info page, and select Manage Zigbee Device, Clusters, select TuyaMCUSiren cluster and then you have the option to I can change the volume and melody through variables (for instance I can set variable melody
to value 3
, volume
to 1
, and so on.).
Now, this works very well, but it is manual procedure. Is it possible to create automation, for instance:
- When “smart button number 1” is pressed:
- set variable
melody
to value3
,volume
to1
- ring two times
- stop
- When “smart button number 2” is pressed:
- set variable
melody
to value1
,volume
to3
- ring one time
- stop
How to do that?
P. S. More info about that problem is here, unfortunately ticket is still open…
