Sure, no problem:
Full automation:
- id: '9493688666'
alias: 'Cat to-do reminders'
- platform: state
entity_id: sensor.person1_iphone_battery_state
to: 'Not Charging'
for:
minutes: 5
- platform: state
entity_id: sensor.person2_iphone_battery_state
to: 'Not Charging'
for:
minutes: 5
mode: parallel
condition:
- condition: time
after: '06:00:00'
before: '11:00:00'
- '{{ is_state("input_boolean." + trigger.id + "_good_morning", "off") }}'
- '{{ is_state("person." + trigger.id, "home") }}'
- action: todo.get_items
entity_id: todo.pet_care
status: needs_action
response_variable: pet_care_to_do
- condition: '{{ pet_care_to_do["todo.pet_care"]["items"] | count != 0 }}'
- repeat:
for_each: '{{ pet_care_to_do["todo.pet_care"]["items"] }}'
sequence:
# Tests whether repeat.item due date is in 10 days
- if:
{% set due_date = expand(repeat.item)["due"] %}
{% set now_date = (now()).strftime ("%Y-%m-%d") %}
{{ (due_date | as_datetime) > (now_date | as_datetime) and
(due_date | as_datetime) - (now_date | as_datetime) == timedelta(days=10) }}
then:
- action: notify.all_ios_devices
title: '{{ expand(repeat.item)["summary"] }}'
message: Reminder, this to-do is due in 10 days.
And here’s the trace:
"trace": {
"last_step": "action/2/repeat/sequence/0/if/condition/0",
"run_id": "7b4fe4129064100d062bb883e140a3c7",
"state": "stopped",
"script_execution": "finished",
"timestamp": {
"start": "2024-08-15T07:43:38.232940+00:00",
"finish": "2024-08-15T07:43:38.249979+00:00"
"domain": "automation",
"item_id": "9493688666",
"trigger": null,
"trace": {
"trigger": [
"path": "trigger",
"timestamp": "2024-08-15T07:43:38.233242+00:00",
"changed_variables": {
"this": {
"entity_id": "automation.cat_to_do_reminders",
"state": "on",
"attributes": {
"id": "9493688666",
"last_triggered": "2024-08-15T01:54:32.747827+00:00",
"mode": "parallel",
"current": 0,
"max": 10,
"friendly_name": "Cat to-do reminders"
"last_changed": "2024-08-15T07:43:29.894429+00:00",
"last_reported": "2024-08-15T07:43:29.894429+00:00",
"last_updated": "2024-08-15T07:43:29.894429+00:00",
"context": {
"id": "01J5AFVR360VPPHQZMYDQ1N2BA",
"parent_id": null,
"user_id": null
"trigger": {
"platform": null
"action/0": [
"path": "action/0",
"timestamp": "2024-08-15T07:43:38.234322+00:00",
"context": {
"id": "01J5AFW07RKMDFPWKE4HMDRAM4",
"parent_id": "01J5AFW07RSQPFW2003GVX3JPG",
"user_id": null
"pet_care_to_do": {
"todo.pet_care": {
"items": [
"summary": "Cat flea treatment",
"uid": "bfb3c77a-5a86-11ef-a949-e45f01e623b1",
"status": "needs_action",
"due": "2024-09-16",
"description": "Treat Yuna for fleas."
"summary": "Cat worm treatment",
"uid": "c58dc326-5a86-11ef-a949-e45f01e623b1",
"due": "2024-09-23",
"description": "Treat Yuna for worms."
"result": {
"params": {
"domain": "todo",
"service": "get_items",
"service_data": {
"entity_id": [
"todo.pet_care"
"target": {
"entity_id": [
"todo.pet_care"
"running_script": false
"action/1": [
"path": "action/1",
"timestamp": "2024-08-15T07:43:38.240825+00:00",
"result": {
"result": true,
"entities": []
"action/2": [
"path": "action/2",
"timestamp": "2024-08-15T07:43:38.241892+00:00"
"action/2/repeat/sequence/0": [
"path": "action/2/repeat/sequence/0",
"timestamp": "2024-08-15T07:43:38.243518+00:00",
"repeat": {
"first": true,
"index": 1,
"last": false,
"item": {
"timestamp": "2024-08-15T07:43:38.247031+00:00",
"repeat": {
"first": false,
"index": 2,
"last": true,
"item": {
"action/2/repeat/sequence/0/if": [
"path": "action/2/repeat/sequence/0/if",
"timestamp": "2024-08-15T07:43:38.244051+00:00",
"result": {
"result": null
"timestamp": "2024-08-15T07:43:38.247186+00:00",
"result": {
"result": null
"action/2/repeat/sequence/0/if/condition/0": [
"path": "action/2/repeat/sequence/0/if/condition/0",
"timestamp": "2024-08-15T07:43:38.244141+00:00",
"error": "In 'template' condition: UndefinedError: 'list object' has no attribute 'due'"
"timestamp": "2024-08-15T07:43:38.247255+00:00",
"config": {
"id": "9493688666",
"alias": "Cat to-do reminders",
"trigger": [
"platform": "state",
"entity_id": "sensor.person1_iphone_battery_state",
"to": "Not Charging",
"id": "tom",
"for": {
"minutes": 5
"entity_id": "sensor.person2_iphone_battery_state",
"id": "teague",
"for": {
"minutes": 5
"mode": "parallel",
"condition": [
"condition": "time",
"after": "06:00:00",
"before": "11:00:00"
"{{ is_state(\"input_boolean.\" + trigger.id + \"_good_morning\", \"off\") }}",
"{{ is_state(\"person.\" + trigger.id, \"home\") }}"
"action": [
"action": "todo.get_items",
"target": {
"entity_id": "todo.pet_care"
"data": {
"response_variable": "pet_care_to_do"
"condition": "{{ pet_care_to_do[\"todo.pet_care\"][\"items\"] | count != 0 }}"
"repeat": {
"for_each": "{{ pet_care_to_do[\"todo.pet_care\"][\"items\"] }}",
"sequence": [
"if": [
"{% set due_date = expand(repeat.item)[\"due\"] %} {% set now_date = (now()).strftime (\"%Y-%m-%d\") %} {{ (due_date | as_datetime) > (now_date | as_datetime) and \n (due_date | as_datetime) - (now_date | as_datetime) == timedelta(days=10) }}"
"then": [
"action": "notify.all_ios_devices",
"data": {
"title": "{{ expand(repeat.item)[\"summary\"] }}",
"message": "Reminder, this to-do is due in 10 days."
"blueprint_inputs": null,
"context": {
"user_id": null
"logbookEntries": [
"name": "Cat to-do reminders",
"message": "triggered",
"source": null,
"context_id": "01J5AFW07RKMDFPWKE4HMDRAM4",
"when": 1723707818.2333784,
