Automation to publish temperature on MQTT - need help
Hello
I have some sensors connected via Homekit. I can see the values in Lovelace frontend.
I want to send the temperature value every x minutes on my MQTT server.
I’m unable to recover the sensor value to publish it, could you help me to discover what I made wrong ?
My automation is
  • id: ‘1999999’
    alias: TempExt
    minutes: /1
    platform: time_pattern
    • data:
      payload: {{sensor.temperature_and_humidity_sensor_9999_temperature}}
      topic: mytopic
      service: mqtt.publish
When the payload is a numeric value manually entered (ie 5) = it works.
I tried the payload without {}, with one pair, whith 2 pairs = still KO
Thanks for your help
Lionel
Update
I made tests using mqtt.publish service in the dev tools on the HA front-end. I can now see directly the result.
payload_template: ‘{{ sensor.temperature_and_humidity_sensor_999_temperature }}’
–> UndefinedError : ‘sensor’ is undefined
payload_template: ‘{{ temperature_and_humidity_sensor_999_temperature }}’
–> published, but no data
payload: 55
–> published with the good data
My conclusion, I have a problem in template evaluation to recover the temperature of the sensor
Ant idea ?
Hi @LL91, did you manage to publish the temperature every minute? I need to do this too :).
yes I use an Automation
with trigger - Time model envery /5 minutes
with action :
payload_template: ‘{{ states.sensor.nameofmysensor.state }}’
topic: myMQTTtopic
and multiply this block for each sensor
