foxy82
(foxy82)
August 16, 2018, 9:50am
1
I have an rfxtrx transceiver and a lightwave mood switch.
I have added the mood switch to HA and now I want to configure automation when it is pressed.
When I press the buttons on the switch I get messages like this in the log:
2018-08-16 10:44:34 DEBUG (Thread-3) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: f29ccb16 Class: LightingDevice Sub: 0, Pkt_id: 0a140000f29ccb10030050)
2018-08-16 10:44:34 DEBUG (Thread-3) [homeassistant.components.rfxtrx] Device_id: f29ccb16 device_update. Command: Mood1
2018-08-16 10:44:40 DEBUG (Thread-3) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: f29ccb16 Class: LightingDevice Sub: 0, Pkt_id: 0a140001f29ccb10040060)
2018-08-16 10:44:40 DEBUG (Thread-3) [homeassistant.components.rfxtrx] Device_id: f29ccb16 device_update. Command: Mood2
2018-08-16 10:44:46 DEBUG (Thread-3) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: f29ccb16 Class: LightingDevice Sub: 0, Pkt_id: 0a140002f29ccb10050050)
2018-08-16 10:44:46 DEBUG (Thread-3) [homeassistant.components.rfxtrx] Device_id: f29ccb16 device_update. Command: Mood3
How can I create automation off the back of this?
lolouk44
(lolouk44)
August 16, 2018, 9:56am
2
this is how I defined my doorbell which would behave in pretty much the same way as your button…
- platform: rfxtrx
automatic_add: True
devices:
0716004500910560:
data_type:
- Sound
fire_event: true
fire_event
is the key word here
and here’s the automation bit:
- alias: Doorbell Notification
- platform: event
event_type: signal_received
event_data:
entity_id: sensor.doorbell_sound
foxy82
(foxy82)
August 16, 2018, 12:40pm
3
Thank you! Yes it was the “fire_event” the rfxtrx document doesn’t really document that option very well.
Then my trigger is as follows.
alias: Mood Switch
- platform: event
event_type: button_pressed
event_data:
entity_id: switch.mood_switch
state: mood2
Obviously it can also be mood1, mood3, mood4.
mcon
(Matt)
April 25, 2020, 10:51am
4
Hi - I have a problem with the same hardware.
Top row is working fine - shows up automatically, but the bottom row, I can’t see the entities appearing anywhere.
I had a look in the home assistant log, but there’s no records like what you’re seeing - is that log from another place in the filesystem?
foxy82
(foxy82)
April 25, 2020, 5:29pm
5
The entities don’t appear it is an rfx event
mcon
(Matt)
April 25, 2020, 9:31pm
6
I see what you mean - the thing I’m missing is that ID you’re getting of the RFX device. Can you point me to the place I can see it when I press the button?
foxy82
(foxy82)
May 18, 2020, 12:46pm
7
lolouk44:
automatic_add: True
If you do this on your yaml it should create an entity for you.
foxy82
(foxy82)
May 26, 2020, 7:33pm
8
Interestingly stuff that used to be working for me has stopped working now - i’m not sure why yet.
foxy82
(foxy82)
May 27, 2020, 7:26am
9
Never mind false alert - I had two switch sections in my config.
