I have an automation set up to make nightly backups to the “backup” directory, but want to limit the number of backups to 2, to save disc space.
Here’s what I’ve done.
Script in config directory, named “remove_old_backups.py”
import os
backup_directory = "/backup" # Replace with the actual path to backup directory
backups_to_keep = 2 # Number of backups to keep
backup_files = [filename for filename in os.listdir(backup_directory) if filename.endswith(".tar") or filename.endswith(".tar.gz")]
backup_files.sort(key=os.path.getmtime, reverse=True)
for filename in backup_files[backups_to_keep:]:
filepath = os.path.join(backup_directory, filename)
os.remove(filepath)
print(f"Deleted old backup: {filename}")
new lines at end of configuration.yaml file:
# Remove old backups
shell_command:
remove_old_backups: 'python /config/remove_old_backups.py'
Automation file:
alias: Remove Excess Backup
description: ""
- platform: time
at: "03:00:00"
condition: []
- service: shell_command.remove_old_backups
data: {}
mode: single
Trace result from running the automation:
Executed: 13 August 2023 at 14:45:16
Result:
params:
domain: shell_command
service: remove_old_backups
service_data: {}
target: {}
running_script: false
The old backups are not removed.
I have tried running the service directly from “developer tools” >> “services”. A green tick appears, which I guess means that the script has run correctly. But no backups deleted.
Feel that I should be able to get some more logs to track down the issue, but can’t find any…
Any ideas?
