Automation to return sensor value that triggered it
Hi. I have high & low temp alarm automations. My aim to add a list of entities that can trigger it, then have the automation send the alarm with the info on which entity triggered it. It seems to partially work, but I can’t get it to report the current temperature with
trigger.to_state.state
The complete high temp one is as follows:
service: notify.gmail
data_template:
  title: >-
    ALERT - High temperature alarm in":" {{
    trigger.to_state.attributes.friendly_name }}
  message: >-
    Temperature is high - current temperature is {{
    states('trigger.to_state.state') }} {{ '°C' }}
What am I missing?
Try this:
  message: >
    Temperature is high - current temperature is {{ trigger.to_state.state }} °C
Brilliant, thanks a lot. I’m having trouble understanding the syntax for templates. Am I interpreting correctly that anything wrapped in states, as ‘X’ below, has to be explicitly referring to an entity?
{{ states('X') }}
Whereas the one below is dynamic?
Yes, exactly. And a trigger variable is not an entity.
The other thing that trips people up when learning templates is the difference between an entity attribute and a state object property. Petro wrote a great post on that here:
