Automation to send notification to iOS after vacuuming?
This is an example I have made, I know I can use If/Else/Then for this, but I have more automations like this with more conditions, where I cannot use If/Else/Then.
What am I doing wrong here? It looks like it triggers, but I don’t receive anything on my phone. I know it is setup correctly because I can test send the notification and that part works.
Is there something wrong with my sequence?
Thank you!
alias: Robotdammsugare - Färdig
description: ""
  - platform: event
    event_type: dreame_vacuum_task_status
    event_data:
      completed: true
      cleaning_mode: SWEEPING
  - platform: event
    event_data:
      completed: true
      cleaning_mode: MOPPING
condition: []
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ trigger.event.data.cleaning_mode == 'SWEEPING'}}"
        sequence:
          - variables:
              text_status: Städning
      - conditions:
            value_template: "{{ trigger.event.data.cleaning_mode == 'MOPPING'}}"
        sequence:
          - variables:
              text_status: Moppning
    default:
      - service: notify.mobile_app_iphone
          title: Robotdammsugare
          message: "{{ text_status }} färdig ({{ trigger.event.data.cleaned_area }}m²)"
            group: robotdammsugare
            url: /lovelace/hem#dammsugare
mode: single
Didn’t give your YAML a long read, but I’d definitely use Trigger IDs instead of template conditions:
Also only looks like you’re sending a message if it’s NOT being triggered (the default actions only run when none of the others are ran in a choose)?
Tried simplifying it removing the variables, but I still cannot get it to work:
description: ""
  - platform: event
    event_data:
      completed: true
  - platform: event
    event_data:
      completed: true
condition: []
  - choose:
      - conditions:
        sequence:
              message: "Städning färdig ({{ trigger.event.data.cleaned_area }}m²)"
      - conditions:
        sequence:
              message: "Moppning färdig ({{ trigger.event.data.cleaned_area }}m²)"
    default: []
mode: single
I get this error:
 websocket_api script: Error executing script. Error for call_service at pos 1: Error rendering data template: UndefinedError: 'trigger' is undefined
are you getting that error when you are hitting ‘run’? or are you getting it somehow when the automation is triggered by the event you are defining?
when u hit run, the trigger object isn’t defined… because there’s no trigger invoking it… so that would be the expected behavior.
to test it, you actually need to make the real trigger happen.
The error is when it is triggered by the vacuum itself.
could you try this and see if you’re getting the same issue?
description: ""
  - platform: event
    event_data:
      completed: true
  - platform: event
    event_data:
      completed: true
condition: []
      message: |
        {{ trigger.id }} färdig ({{ trigger.event.data.cleaned_area }}m²)
mode: single
if you are, replace ({{ trigger.event.data.cleaned_area }} with a hardcoded string (no {{ }} )
